Question about Epson Stylus CX6600 All-In-One InkJet Printer
My black ink doesn't print - Epson Stylus CX6600 All-In-One InkJet Printer
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Epson tx700w black ink doesn't printing well.
1st a fall u must purchase original cartridge 2nd clean the head 3rd print the alignment page.
Be careful when u clean the head.
It is better if you use contact cleaner for head cleaner.
IN SHA ALLAH the problem will
Oct 06, 2017 | Epson TX700W Series
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
My desk jet 3320 printer do not print black
Are you sure there is enough level on the black ink cartridge.. if does try to do "print head clean up" if doesn't fix the problem consider to replace the black ink cartridge
Aug 31, 2012 | HP DeskJet 3320 InkJet Printer
HP 5150 Deskjet -- black printing abruptly stopped. Prints appear with color but no black. Switching black cartridges doesn't help. Clean print heads operation doesn't help. Switching computers...
There are very few things you can do, other than what you have aleady done.
I would recommend a decision on how much the unit cost and how long you have used the
printer vrs. what HP or a local authorized service center would charge to repair it.
If you have refilled ink cartridges, this is problem that can arise due to ink drying on the
print head as the black cartridge is use the most.
Aug 06, 2011 | HP DeskJet 5150 InkJet Printer
I have an HP Photosmart 2575 all-in-one printer, and my black is not working I just replaced it with a new cartridge and it still doesn't print the black.
The new ink-cartridge probably is OK.
So, start the HP Printing Assistant Software, and run the "Print-Head-Cleaning" utility, to run a few cycles. Hopefully, it will unclog the ink-jets that _should_ be spraying ink onto the paper.
Jul 25, 2011 | HP Office Equipment & Supplies
Dell AIO Printer 946 I can't print a word document in black and white. When i click on printing preferences, it doesn't allow me to click on " print in black and white" Please help
In printing properties have you selected the 'grayscale' option, if still not working, in printer properties select maintenance > select Ink and cartridge settings > there select "black Ink only"
Jun 01, 2011 | Dell AIO Printer 946
Our Lexmark Prospect Pro205 has sufficient ink in the black cartridge. The error message says there is interference with the black ink cartridge. Black ink does not print, but color inks print.
Your cartridge may need to cleaned. On the printer operator panel, press Setup button -> Maintenance -> Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
If that doesn't help, your printer probably needs to be updated. The firmware update, available at http://bit.ly/p205fw, will help fix print quality issues.
May 02, 2011 | Lexmark Prospect Pro205 Wireless...
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon s200SPx black ink can`t print
Try cleaning the black print head, It might make a difference. You need to do this through your software preferences.
Gremlin11
Dec 13, 2008 | Canon S200X Ink-Jet InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
107 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
