Question about Canon imagePROGRAF W6400 InkJet Printer
Error message I have an message coming up when I am trying to print saying i am unable as MT Cart needs replacing?!?! What is the MT Cart and how do I replace it? Is it something I need to buy? THank you.
  • suanto Jan 03, 2013
    my name is suanto i a prablems questione what it is MTCart full soon help transleet indonesia ma ploter canon w8400 help?
Replace the filter located at the bottom
Posted on Mar 27, 2008
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Error #12 Shows on my lexmark x4270 all in one how do i clear it
Hello there,
In my experience I've never come across an error #12 on a X4270. I've seen an error 1200 & error 1203 a couple of times. Did you get this error after installing a new cartridge? then there are chances that the new cartridge that you installed is defective. The best way to figure if out is to take both the cartridge out and power recycle the printer with the cartridge out. Check out if the operator panel says "cartridge missing" when it is powered back on. If it doesn't say "cartridge missing" then the printer hardware is defective. You would need to get it serviced. If the printer comes up with "cartridge missing" message, then either one of the two carts that you have is defective. I would suggest you to insert one cart first and close the cover and check if it says "cartridge missing" If it does come up with that message then insert the other cart too.. If you get Error 1203 on after inserting a cart, then that cart is defective and needs to be replaced.
Merry Christmas!
Dec 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Nov 26, 2008 | Lexmark C510 Laser Printer
Brother 350c
First printing a photo takes lots of ink , it depends on the color of the photo , cyan is blue which maybe consumed more in the printing or there changes that the ink may have dried in the cart hence your getting this error ,remove cart take damp paper towel and hold the paper on the place where ink comes out gently for 20 second ,make it does not touch copper contact it may damage the cart ,make sure you check the place where ink with dry paper its usually bottom of the cart and repeat the above step with dry paper towel and try to print if you get the same error then you need to replace the cart or you can contact brother support and get cart replaced , once cart is used you need print once in week to keep cart from drying, you can use any photo paper which is compatible with printer .
Good luck....
Good luck....
Aug 24, 2008 | Brother Office Equipment & Supplies
MMy printer will not print, fax, copy, or scan. Theres a messages coming up saying Error#1203
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
Jul 28, 2008 | Office Equipment & Supplies
Error 1203 and carrier jam error
May 24, 2008 | Lexmark P915 InkJet Photo Printer
Printer Ink is Low
If had refilled the ink then this printer as in build sensor which works only once , that reasons your getting this message if your using original Lexmark cart then if your getting this message then you can contact lexmark get the cart replaced as the cart comes with 6 months warranty.
May 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Canon imagePROGRAF W6200
To reset the 'MT CARTRIDGE FULL SOON' error.
Enter Service mode Hold down the paper source and online button at the same time, hit the power button once.Continue to hold down the paper and online buttons until you see the printer name "Canon W6200" on the printers LCD display, then release the two buttons.The printer will initialize & enter service mode.
In service mode, scroll sideways until you see the 'Initialize' menu, scroll down to 'W-ink', and press enter. At this point I did something (scroll sideways and hit enter I think) and it came up with 'New W-ink Cart' Hit Enter to get '=New W-ink Cart' and Online to Accept. I powered down and back up, error all clear.
Jan 08, 2008 | Canon imagePROGRAF W6200 InkJet Printer
Error message
does it say an error after "unable to print",what lights? are all inks good?, is there any bits of torn paper inside where head and carriage side up and down?
Oct 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Open Questions:
See all Canon imagePROGRAF W6400 InkJet Printer Questions
Canon imagePROGRAF W6400 InkJet Printer Logo
691 people viewed this question
old marine
old marine
