Question about GE Profile JGP636 Gas Cooktop
Can you put the top oven grates in the oven while it is self cleaning
    President:
  • 949 Answers
The top burner grates are designed to handle direct heat in excess of self clean temperatures.
You can put the grates in to the oven during self clean... but it will not clean them. The baked on residue needs some chemical reaction to break down the reside on them. I would suggest soaking them in an oven cleaner like easy off. Spray them down good then using rubber gloves put them into a plastic garbage bag, spray them again in the bag and close it up. Let them sit and soak for an hour or so then wash them off. This is best done outside so the odors will not be in the home in an enclosed area.
Posted on Apr 26, 2010
Have cast iron grates with no enamel on them. Burned on grease, etc on grates from previous owner. Can I clean them in a self cleaning oven? If not, what is best way to clean? Thankyou.
I would spray them down with a good oven cleaner ,outdoors and let them sit there soaking a couple days . then wash off and see what they look like .
Apr 15, 2015 | Jenn-Air JGD8130 Gas Cooktop
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Nov 08, 2014 | General Electric GE 24" Single...
I have a drop-in oven from frigidaire.I started the self cleaning process the door did not lock and the light keeps flashing,I dont know how to stop it and i cant use the oven at all.
Good Morning friend, thank you for your post!
I understand that your Frigidaire range is not allowing you to cancel and you are unable to use the oven. I would suggest holding down the "Cancel/Clear" button for ten seconds and that should cancel the self-cleaning. If that does not work I would recommend a reset on your range, you can do that by flipping off the household circuit breaker for ten minutes. I hope this has been helpful. -Matt
Oct 13, 2014 | Frigidaire 30 in. Electric Self-Clean Coil...
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
Kenmore 629
Could be the lock needs replacing the oven won't self clean if the door lock isn't functioning it's a safety thing so you don't get your face burnt .
Ray
Apr 16, 2014 | Kenmore Cooktops
I don't know how to start the self cleaning oven! I don't have a manual and I don't see any buttons that indicate start self cleaning oven!
there should be a button a small button that says self cleaning on the oven mines on the side but just look almost 95% of all ovens have this
Mar 10, 2010 | Whirlpool Cooktops
After running the self-clean feature on my 21 year old Beaumark stove all of the indicator lights (oven, burners)are not working. The clock (not digital) is not working either. Oven and burners are still...
you may have a temp thermo on the back or the top of oven . hi tempt would have shut off electrical . should have shut the oven off also / wiring in top may be faulty. now if the top burners are working but the clock & oven are not then you have a saftey thermo out . you may need to repl with new one . some ary resetable. take the old one to a appliance parts co . so they can read the tempt,s on it ,. should be able to match .. mm
Nov 20, 2009 | Cooktops
Stained gas range burner grates
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
Feb 14, 2009 | GE 30 in. JGP337 Gas Cooktop
Cleaning grates of GE profile gas stove
Sounds crazy, but this works. Soak the grates in warm to hot water with 2 dryer sheets (Bounce), let them soak for an hour or two. Unbeliveable how they came clean. I did have to use a Scotch Brite pad on the two that I use most, but it sure beats replacing them.
Jul 02, 2008 | GE Profile JGP636 Gas Cooktop
GE Profile JGP636 Gas Cooktop Logo
438 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
