Question about RCA L42WD22 42 in. LCD Television
The picture is gone. The sound is great but no picture.
When I first turned on the tv there was apicture but it disappeared. I've turned it off and back on . Reattached all connectors and still no picture. The set is 2 years old.
TODOS LOS DSPOSITIVOS ESTAN BIEN CONECTADOS PERO SALE MENSAJE SIN SEñAL REVISE ENERGIA DESP CONECTADOS Y CONEX CABLE
Posted on Apr 26, 2010
Turn on TV and picture and sound are great for about 60 seconds. Then the picture disappears but sound remains.
I would start with checking the power supply 12vdc output, make sure it is stable with no ripple. If the power supply checks out fine, I would then suspect the main board.
Sep 20, 2012 | Vizio VT470M 47-inch 1080p 120Hz 5ms LCD...
When I first turn on the TV there are 3 transparent lines that appear.
The data buffer IC inside of the display panel is bad. It needs a new panel.
Apr 20, 2017 | Samsung LNT4066F 40 in. LCD Television
Lost picture
Try unplugging everything and then plugging it back in. When my xbox had the "ring of fire" my brother asked me to fix it and I just unplugged and re plugged it worked and came back to life. (be careful that you either have the instuction menu for setup of you can remember where all the plugs go, otherwise you'll have to right down what goes where or else you may get confused and never be able to fix your poor television)
Mar 22, 2012 | Protron PLTV3250 32 in. LCD Television
Turn on picture and sound are great. for about 60 seconds. then the picture disappear but sound is great. turn power off wait a little bit ( try differ times. from 15 seconds to 10 minutes) Turn back...
The tv have a long board call a LCD inverter board.This long LCD inverter board is dead.That why,the tv have picture only flashes like a min. than,died and have sound left only.The LCD long inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Oct 16, 2010 | RCA L32HD32D 32 in. LCD HDTV
My HyVision LCD TV Picture disappears after a few seconds
It seems that the "backlight" has gone bad. "Backlight" is the device that allows to see the picture in an LCD TV, when they are about to go bad the symptom that you describe is very usual. It depends on the tv manufacturers and model to expect how long the "backlight" is going to last in a tv.You can shop around for a replacement part and try to do it yourself or take it to an especialized technician. Good luck..
Jan 03, 2010 | MegaVision Hyvision Megavision 191 19"...
No picture 2 days ago power went out thru out the neighborhood, once power came back TV worked great. today, go to power on TV, here it clicking, but no picture... cable box working, cable working in 2nd...
It sounds like there`s a sort on the secondaries of the power supply. Before the power went off, did you ever turn the tv off by unplugging it?? In other words, did you turn the power off completely to the set or leaving it in standby?? if you always left it in stby, it will be the capacitors in the power supply, they dry out if the power is always on, so they will need replacing. If you did turn off the power, then I think you`ll find that the power cut had nothing to do with the fault you`ve got now, it will be the Line Output Stage which has failed or gone short circuit. Ian
Aug 05, 2009 | Sony Televison & Video
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
AT THE BEGINING THERE IS APICTURE THEN DISAPPEAR
check the horizontal section of the TV. and re solder the pcb at the neck of the CRT, and the main board. check for any leak capacitor, oil discharge in circuit board.
Jun 11, 2009 | Televison & Video
Philips model ptv915 model # 60P8341a
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
KV-32S45 Disappearing Picture, Good Sound
yes you have a bad vertical ic . i,ve seen bad conections on this ic too, it may not need to be replace its a ic that stands up 6 pins the numbeer on it starts with TDA
Apr 19, 2007 | Sony KV-32S45 32" TV
RCA L42WD22 42 in. LCD Television Logo
103 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
