The blower fan does not shut off when it reaches the set temperature. Compressor shuts off but fan continues to run making the air inside very humid. Temperature is getting cold.
    Guru:
  • 415 Answers
First, forgive me, but I have to throw the obvious out there......make sure the fan switch is in AUTO and not ON.
If the blower will not stop operating unless the main supply feed is shut off, you have a stuck blower relay that will need to be replaced.
Posted on Apr 26, 2010
Should the fan shut off when the humidity setting has been reached for model Frigidaire CAD504DWL 50-Pint Two Speed?
Thank you for your post, friend!
I see that your question is if the fan should shut off once it has reached the recommended setting. The fan will run even when the compressor cuts off so that air can pass over the sensor coils to check the humidity. This is a normal operation. I hope this is helpful. -Matt
Sep 12, 2014 | Dehumidifiers
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
Bought 4 small Gold Star units in 2009. One quit cooling altogether, one blows slightly cool while the longer another stays on the less it cools. One did not cool well when it was new. All filters are in...
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700000&pkw_=basket&model_id=5520000&NewWindow=1
Download this illustration and then using a good multimeter start basic troubleshooting.
All residential window air conditioners have a cooling system made up of four primary components, a compressor, an evaporator fan, a control or switch, capacitor.When the thermostat is calling for a colder room temperature the compressor is energized. It is normally very quiet. The evaporator is always located on the front of the air conditioner. It also has silver fins. Be sure it is clean. Use a foaming type cleaner and rinse with plain water. Because the evaporator is absorbing heat, it is very cold to the touch. The temperature drop causes any humidity in the air to collect on the evaporator - sometimes called sweat. There is a fan inside the air conditioner that circulates the air for the evaporator and condenser coils. The circulating fan and compressor are running simultaneously. The fan motor has two fan blades attached to it on either end. The fan blade on the inside part of the unit continually draws room air over the evaporator coils, which are cold. The fan blade on the outside part of the unit continually draws fresh outside air over the condenser coils, which are warm. Because the evaporator coils are cold, they cause moisture in the room to collect on them, much like a cup of ice water on a warm, humid day. When the amount of moisture increases, it begins to drip down off of the coils into the bottom pan of the air conditioner.
If the compressor fails to start or the fan you may need to replace the capacitor.
You may need a hard start kit.
Thermostat control The thermostat on a window air conditioner works by sensing the air temperature entering the air conditioner. As the air entering the unit reaches the set temperature it will cause the compressor to turn off. The blower may continue to run depending on the selection chosen on the control panel. Digital thermostats work on a similar principle but display a more precise temperature.
Test for continuity with the multimeter between the two terminals . Warm you should read continuity (contacts closed). If not change it.
Selector switches The air conditioner selector switches allow the user to choose the fan speed. The compressor always runs at the same speed regardless of the settings. If low cool is chosen, for example, the fan runs at a slower speed but the compressor still offers the same cooling capacity. There are other switches to control louver operation and other features on some units.
Jul 23, 2011 | LG Goldstar GWHD5000 wall/window Air...
When the humidity set point is reached, the compressor shuts off but the fan continues to run. Is this normal?
Chucke - Depending on which mode you're operating the unit in (Continual Mode), yes that is normal.The fan continues to run in an effort to recirculate the air. If it senses a rise in humidity above the level you have it set on, the compressor will turn and remove that humidity.
Hope this helped you.
Jun 27, 2011 | Frigidaire Dehumidifiers
Does the fan on a Kenmore dehumidifier run continuously, or does it shut off when the set point is reached? I returned a Frigidaire unit because the fan is designed to run continuously.
That depends on the manufacturer and in what mode you are operating it. If it's Continuous Mode. Yes, the fan will continue to run, as it's recirculating the air, in an effort to determine if and when the humidity level rises. Then the compressor will turn ON to extract the humidity.
Also, most units will do this if they are running thru the Defrost Cycle. This happens when the cooling coils frost over. It to, is a normal cycle.
So, if you are operating the dehumidifier in Continuous Mode, it's acceptable.
Hope this helped you. Please let me know. Thanks.
Jun 18, 2011 | Kenmore 54501 Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Jun 06, 2011 | Danby Dehumidifier
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!!
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Outside fan and compressor does not shut off
the system is wrong, the blower must run continuously , and the compressor is the will stop if the temperature setting is reached. The outside fan is the same as the comp.
Jun 16, 2009 | Heating & Cooling
LG LD65E humidity variance
Is the compressor running or is it just the fan? If its just the fan it is because it is cycling the air and it uses that air flow to check the humidity in the air. If the fan runs non-stop and the compressor does not turn on or the fan does not shut off there is a problem with this unit and you will need to replace it. Since it is brand new you should still be able to return it to the store.
Jun 27, 2008 | LG LD65EL Dehumidifier
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
