Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Pencil point bright spots on screen first one now three WD65733
  • Allen Kauk
    Allen Kauk Apr 26, 2010
    yes gives me something to go on when I check the TV Out
  • Mitsubishi Master
  • 19,396 Answers
Hi.
If the points are light points and are coming up always in same place, then you have a faulty optical group.
The optical group (light engine) is probably the most expensive part in a rear projection TV. Depending on the fault, the part cost may be covered by the manufacturer.
The first thing to do is contacting Mitsubishi at the number listed on the owners manual, and asking them a quote on repair. If the problem is the light engine, I suggest complainining about the fact that no improper use of the set had been done, and that the problem is probably the consequence of a factory defect.
Regards.
Posted on Apr 26, 2010
I have a Mitsubishi WD65733 it had the white dots all over the screen. I replaced the DLP chip and that fixed it for a few minutes then the screen went bright white. Now when I turn it on the screen is...
Hello, the main chip in the "light engine" has gone bad. Mitsubishi had a program that they were sending out the chip at no charge, but wouldn't pay the labor of changing it. I don't know if they still have that program going, but you might want to contact them. tks
Nov 05, 2013 | Televison & Video
BRIGHT SPOTS ON MULTIMEDIA PROJECTOR SCREEN: SHARP XR-32S-L USED FOR 2.5YEARS DISPLAYS MANY BRIGHT SPOTS ON THE SCREEN? IS THE PROBLEM IN THE DMD? SHOULD REPLACE THE DMD OR BUY A NEW ONE? DINESH MUMBA
it is the problam of your dmd chip i think the dmd chip 304 small like a simcard change the chip your problam will be solved 100%
i will show you the chip
Nov 07, 2012 | Sharp XR-32S Projector
Some of my pictures have a spot on them. like a "water" spot. i thought i was on the lens but two or three pics will be ok then one will spot. any clue?
The clue was that not all of your pictures had this spot or two. What I expect from what your wrote is that these spots are what is called lens flair. It's caused by a strong point of light entering the lens at an angle. Such points of light are common in landscapes on a bright sunny day, reflection off water or some other shiny surface. If the camera was used at night the "spots" could be coming from a street light. Most of the time it's the sun, the only way to stop this is first to be aware that it could happen when the camera is pointed to an gale of the sun. What you do for a point and shoot is hold your one hand over and above the lens sort of like the peak on a cap. Make sure your hand is high enough to be out of the camera field of view but still offer some shade to the lens. I do this but normally with the camera mounted to a tripod and i use my hat.
Have fun
Jan 14, 2011 | Sony Cyber-Shot DSC-T5 Digital Camera
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
Three small white spots appered on the screen. about the size of a pencil eraser.?
Light Engine call Encompass Parts 1-800-638-3328 or try UED 1-800-648-6657 .you will begin to have more white spots appearing as time pasts .
Nov 21, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Is coming alot of bright spot all over the screm like a little point isee the channels whith the spot
These are failing pixels in the matrix. Eventually the screen will not be viewable.
The screen is made of millions of points of l;ight called pixels They turn on and off to create what you see on the screen. When they fail they become minute white spots.
Aug 21, 2009 | Samsung HL-S4666W Television
THREE BRIGHT BLUE SPOTS ON THE BOTTOM AND ONE ON THE TOP OF SCREE
Sorry, pero tu problema no tiene solucion, solo por garantia......
but I have something for you....
1. unplug the TV.
2. press and hold ch -
3. conect the plug again (green ligth on)
4. release ch - (service manu apear)
5. with remocon press down two or three times (find something like mp3) and change value from 0 to 1.
6. press exit
7. connect USB with pics and mp3 music.
8. check the pictures and.... the music start...
note. the USB slot must be empty before unplugged the cord.
Jul 04, 2009 | Sanyo Televison & Video
Small spot on screen
you have dust on your projector, you should be able to take the screws out around the screen, lean the screen away from the tv, and wipe dust off the projector
Jan 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Cds will not open
New CDs may have some rough spots around the inner and outer edges. If such a CD is used, this unit may reject the CD. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Dec 26, 2005 | Panasonic SC-PM31 Shelf System
CD doors will not open
Dec 20, 2005 | Panasonic SC-AK25 Shelf System
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
