Question about Hayward SAND FILTER, PRO SERIES
Water is running out from the waste line when i turn to filter .
My name is Harry tang,L installed a Hayward sand filter s180t last week my promblem is when i turn to filter position the the water come out from the waste line too.Can you tell me what i have to do,Thank you
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
You need to check and probably replace the gasket inside the valve to stop the leak. The gasket kit is pretty cheap and not to hard to replace. We can try to get you the part number if you can post the valve brand and model. You should be able to call any local pool store with the brand of filter and get the part you need without any trouble.
Be sure in the future that no one adjusts the valve setting without turning the pump off. Moving the handle with the pump on can dislodge the gasket and then releasing the handle damages the gasket.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 26, 2010
I have a Hayward s166t sand filter and no matter what setting I have it on tons of water is coming out of my waste line! This is my 1st pool and 1st sand filter!!
I used to work in a municipal swimming pool. 325,000 gallons!
It sounds like you have the sand filter on to clean if water is coming out of the waste line. That is called 'back flow'.
Basically, the water from the pool comes into the top of the filter and the muck settles on the top. You need to add Gypsum (Aluminium Sulphate) to the water which is a floculant. This makes organic material form into a layer on top of the sand. The flocculated layer further adds as a filter. You need to regulate the flow of water into the filter as too fast and you force sand into the pool.
When you clean the sand filter, you do a back flow. So by altering valves, you put the water from the pump into the bottom of the filter and the water lifts the muck and dirt off the top of the sand and discharges it to waste. It is important to also regulate the flow as too much will discharge the sand. That happened in our municipal pool and discharged 6 tons of sand in the space of 2 years.
your owners guide is here. Take a look at the pipes, valves and pump and work out where the flow is going to.
http://www.hayward-pool.ca/pdf/manuals/ProSeries-S166T-S166T1575XS-S166T1575XSN2.pdf
Jul 03, 2016 | Hayward Pool & Spa
How to backwash sand pro 550
turn filter off turn multiport to backwash turn pump on you should see water coming out of the waste line (make sure you have a hose on it with clamps) run for a coupleof minutes until water in sightglass goes from dirty to clear turn off pump turn multiport to rinse turn pump on run for 30 sec then turn off turn multiport to filter then turn back on thats all
Jul 17, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
If I turn to back wash, will I lose sand. Should I use waste out to clean the filter
Backwash is meant to clean the sand and remove dirt from the filter.
Waste simply pumps the pool water to the drain line and doesn't clean the sand.
If the filter has its distributors, the sand should be held in the canister.
Gary
Jun 27, 2011 | Hayward SAND FILTER, PRO SERIES
I was curious about the height of sand needed for the filter to work properly for my Hayward pro series 180T sand filter. It is one of the old gray colored models, and would you mind giving me an...
A Hayward S180T sand filter holds 150# of sand. In other words, fill the filter 3/4 full of sand (to the point where the tank starts to round off). Make sure, however, that you fill the tank 1/2 full of water first. This will help to cushion the laterals and prevent them from breaking from the weight of the sand. Make sure to cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent sand from going into the pipe. If sand gets into the pipe, it will come out into the pool. Don't forget to remove the cup or tape after adding the sand!
Jun 15, 2011 | Hayward SAND FILTER, PRO SERIES
Just installed a hayward pump and followed directions on the pump having problems when we tried to backwash it shoots sand into the pool
Backwash should put no water back into the pool. It should be sending filter dirt to a waste line. Maybe your lines are incorrectly installed?
Secondly, under normal conditions, sand does not go to backwash waste either. Could there be too much sand in the filter?
Gary
May 01, 2011 | Hayward Pool & Spa
Hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward S180t filter w/ hayward sp 711 multiport valve. I removed to multiport valve to fix the spider gasket. I didn't think to mark so I could put the multiport valve back on. I need to know how to put...
Hayward 711A13 Vari flow valve. When I push down the handle to move valve into other settings the handle does not want to relock into the next setting. I have to manually pull up un the back of the handle and tap with my hand to get spring to retract. What can I do to lubricate this sping inside?
Apr 28, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter needs primed every time
The problem is a malfunctioning check valve. It'll be somewhere in the line on the pump output side. If it's not a separate fitting it'll be in the line, probably in an elbow.
Need further info, let me know...
Charlie
May 29, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
411 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
