My Samsung 2243BWX Screen has this problem everytime I turn it on and use it. The screen, on average once a minute, will go black for a few seconds and then come on again. Sometimes it happens once every 5 minutes, sometimes every 10 seconds! It's kind of like it's refreshing the screen. I've had a go at playing with the "Display Time" in the monitor's settings menu and set it to the maximum 200secs - but I don't think that's the issue as the blackouts haven't changed a bit. Also - everytime the screen does this for a couple of seconds, when it returns it will always have the little dialogue box in the top left hand corner of the screen that says "ANALOGUE 64.8kHz 60Hz PN 1680x1050" which is just the standard infomation about the monitor settings but it's weird that it pops up everytime the screen blackout and refreshes itself. It's just extremely annoying, especially when I'm trying to work or play a game or watch a video. HELP PLEASE!
    President:
  • 1,188 Answers
As per your description the monitor is disconnected from the computer and then reconnected. That is why the message pops up. To troubleshoot you may have to open the PC cover and investigate but we will leave it as a last resort.
To begin,you must disconnect the PC and monitor from the power source.
First look at the back panel of the LCD and check the connection of the VGA cable. There are two screws which you can turn by hand or a flat screw driver. Loosen them and remove the jack. Do the same with the other end connected to the PC's VGA out.
If you have a can of compressed air or a blower use it to remove dust off the jacks and replug them making sure the screws are tight but not too tight or you will damage the connector. Just tighten them by hand.
Now see if the problem is gone or not.
The next step would be to re-seat the video card if you are using a PCI or AGP card. If its an onboard VGA then skip this step. You must take caution or you will end up with a non working PC. If you are not comfortable doing this ask a friend or take it to a computer shop. But its not that difficult. Try to do it with a frind's help to save cash.
If the issue persist which is unlikely then try a new cable. You LCD also has a jack for DVI-D input:
You can also use a DVI-D or VGA to DVI-D cable if you r video card supports. Refer to the quick start guide or manual on how to perform connections.
Posted on Apr 26, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Screen goes black for a second or two every few minutes
This indicates the inverter transformer is going or a capacitor issue.
May 08, 2012 | HP LP3065 Monitor
Everytime i turn my calculator on the screen is black it's a like a black rectangle. how can i fix this and get my calcualtor working normally again?
Adjust the screen contrast. Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key for a few seconds to lighten the screen. If you go too far, repeat the process using the 2ND and up-arrow keys.
Dec 09, 2010 | Texas Instruments TI-83 Plus Calculator
The monitor startup and few seconds later it turn
You are going to have to open up the monitor, please read below if you are going to DIY.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 216BW Monitor
TI-84 Plus Calculator: my calculator screen is black everytime i turn it ...
Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key for a few seconds until the screen lightens.
Obviously, if you've gone too far, press and release the 2ND key, then press and hold the up-arrow key.
May 17, 2010 | Texas Instruments TI-84 Plus Calculator
Screen turns black or bright green
mine did that but only on halo 3 you should try to blow in where you put the discs n if not then sry I couldnt help you but yeah i had to keep blowing in there casue it was dusty but now its just keeps saying Unplayable Disc??
Jun 04, 2008 | Microsoft Xbox 360 Console
Samsung SyncMaster 204bw....keeps going black every now and then with the power light flashing, i don't understand what is wrong with it :S please help?? i have to restart my system everytime...
Similar problem with Samsung Syncmaster T260 at 1920x1200 on HIS Radeon X1950XTX video card. Black horizontal stripes lasting 1/60th of a second or so every few seconds, then black screen for 2 seconds, then fine again.
I Set the catalyst control center control panel for the graphics card to Alternate DVI operational mode under the Digital panel attributes item. Setting the screen to 1600x1200 also seems to stop it doing this. BUT...it didn't used to do it. Bought it in November, and it didn't start doing this until late January. Go figure.
Apr 04, 2008 | Computers & Internet
Tv screen goes black for a few seconds
do you get sound while screen does black? what do you mean by "until eventually it has turned black and will not come back"? is it black from the minute you turn the tv on untill you turn it off? if sound is good but picture is black, it may be the resault of a fried monitor tube, in this case replacement will cost alot. if sound is dead also, them it is probobly power supply related issue. get out your DMM and measure the voltages in the power supply. When the screen goes black, is there still regulated B+ going to the circuitry? Do you still have HV? Is the filament of the CRT lit? Does the set still have a raster (you may have temporarily increase the screen setting to see it)? Do you measure any of the flyback derived B+ voltages that go to the video processing, tuner, Vertical Deflection, and other circuitry?
Mar 19, 2006 | Samsung TXD1972 19" TV
Computers & Internet Logo
David Payne
David Payne
