Question about Kitchen Ranges
I have a GE Profile free standing gas range JGB920sefss, the display for the clock & oven temp etc doesn't work so we can't use the oven, but the burners and interior oven light work any ideas???
  • 576 Answers
Sorry, usually that is a bad control board. It looks like they are available at www.appliancepartspros.com for $121.50 You'll have to decide if it is worth fixing.
Posted on Apr 26, 2010
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Purchased GE Profile dual fuel range 6 months ago. Clock has always run fast and today the entire touchpad control went dead. The oven light works as does the gas burners. I am not sure if I inadvertly...
Unplug the unit and wait 2 FULL MINUTES before plugging it back in. That will reset the circuit board and you should be good to go. If it doesn't work, my bad!!!!!!
-AGK
Apr 17, 2011 | GE Profile JGSP44 Dual Fuel (Electric and...
My GE profile gas range jgbp79wewiww the clock blinks f-2 and i have to light the burners with a match tks for any help
Hi There
I have found the code for and hope this helps you.let me know how it goes.
F2 During Bake Control senses oven temp above 590 degrees F High resistance connection in oven temperature sensor circuit. Check Electronic Range Control (ERC) - Welded bake relay contactsThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | GE Profile JGBP79 Gas Kitchen Range
The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Jun 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Claibrating the temperature of a GE gas oven
5 degree increments from factory setting
1 is +5
2+10
and so on
Apr 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Kitchen Range
have you tried clock then setting it
Feb 16, 2008 | Kitchen Ranges
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
May 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
