Question about Toshiba 65H82 65" Rear Projection Television
My TV would not turn on then after unplugging it it finally did but there is a smell, like something burning (burnt) and the picture is wavy it's a 55" JVC about five years old
    Problem Solver:
  • 5 Answers
Check fuse in power supply
Posted on Apr 26, 2010
SOURCE:
Thomson 50DSZ644. Just replaced the Lamp great picture but burned smell.. after few house it smelled verry bad..and i turned off. now when i turn on the tv the picture in middle is dark and still thi
should have unplugged it when you noticed the smell.
UNPLUG and remove and look at lamp you installed--is something in the housing where lamp goes melted? I hope you did not touch the face of the bulb with your hand or fingers.
What ever is wrong find it before trying to use set again.
Dec 22, 2012 | Thomson 50DSZ644 50" DLP Rear Projection...
Screen is black
sounds like it was enough to pop something in the tv, smell the back of the tv smell if anything smells burnt or hot. unplug the tv and let stand for about a hour unplugged then trying it again but if it does smell chances are you will have to see if your still under warrenty and have the unit replaced.
Aug 09, 2008 | Mitsubishi VS-50605 50" Rear Projection...
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
Got it new at Walmart in 2006? Never had any problems with it, and always had a surge protector. I know the kids have abused it though. Anyway, yesterday they had a pink, washed screen, turned it off/on...
No.The tv video board have dead components,that the board where it is connected to the CRT-(tv picture tube).Troubleshooting that video board and changes parts should fix ur tv problems.Hope ur tv problems,it is not the video board main big IC colors processor inverter.This big IC is a pain to change and probally not in the market anymore.Troubleshoot test all the capacitors around that big IC colors processor inverter alot of times just those few capacitors are dead only.
Apr 02, 2011 | Sanyo HT30744 TV
My tv makes a popping noise when i plug it in and i dont have the remote, how can i fix it?
Sounds like something is burning inside. Is there any smell of burnt plastic coming from the unit? If so, unplug it and dispose of in a metal garbage can. Not worth fixing.
Mar 25, 2010 | RCA 14F512T 14" TV
I have a HD52W55 and it will not come on. heard a pop and smelled something burning, took the back cover off can not find anything obviously burnt but have no lights and no power.
Well, my first guess would be a blow fuse, did you check for that?
But if you smelled something burning, then even if the fuse did blow, it failed to protect something; probably the main power transformer. That's a coil of wire in a sort of square shape that should be near the fuse. Its hard to tell if they're burnt sometimes, but it may need replacement.
Please upload a few pictures so we can have a look too.
Mar 25, 2010 | RCA HD52W58 52" TV
I have a 50803 projection tv. The picture went out. It started with a green tint and lines going across it. I turned off the tv and then turned it back on. Now there isn't any picture at all. There was...
This is very simple to repair if have burning parts smell,replaced parts that burning smell,the parts that cause by the burning smell part,make it to dies that hard to find.My sugestion replaced the DM power board,first to get power back,than go on from there.
Dec 12, 2009 | Mitsubishi VS-50803 50" Rear Projection...
No picture, perfect sound, burning smell
I assume this is an LCD tv that you have? I would think a fault has developed on your inverter board with one of the components having burnt out & shutting off the drive to the backlights hence the smell & lines on the picture. It would be advisible to take it to a repair centre to have it repaired to check the burning issue as a matter of safety
Aug 04, 2009 | Televison & Video
I just replace convergence board on my akai tv and
There is a burnt capacitor somewhere in the unit. Look for any burnt or swelled up capacitors. You can also usually locate a bad cap if there is burn marks on the system board. Also test power supply with voltmmeter to make sure it is a constant volt reading.
Jul 11, 2009 | Akai PDP-42TD1 42 in. EDTV-Ready Plasma...
Tv shuts off
the tv needs a tech to repair your tv it could be anything in the power supply that have burnt good luck.
Apr 07, 2007 | Toshiba 27A34 27" TV
Toshiba 65H82 65" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
