Question about Pass & Seymour #5410WBPCC5 White In Line Cord Switch
Don't know how to fit the wire into the inside of the switch
Have an in-line switch made by Pass & Seymour. Never before installed such a switch. Looking at the inside of the switch where the wire lays, don't know which side the cut wire goes. Also, is it the copper wire that is cut?
    Guru:
  • 509 Answers
Since there are only 2 wires, it doesn't matter which wire goes where. Either way it will work.
Posted on Apr 26, 2010
How to troubleshoot the installation of a Pass & Seymour three way switch
Standard 3way switch. You have two matching colored screws. they are the travelers. The odd colored screw is either power in or switch leg out depending on which end of the line you are on.
Jun 03, 2014 | Pass & Seymour Trademaster TM873WCC10...
Wire diagram tm873
Standard 3way switch. There are two crews the same color, those are for the travelers. The odd colored screw is for the power in or switch leg out depending on which end of the line it is located.
Aug 20, 2013 | Pass & Seymour Trademaster 3-Way 15 Amp...
Installing two pole switch
Copy following link to help identify switch and wiring:
http://waterheatertimer.org/How-to-wire-switches.html#PandS
Add a comment and describe timer and wiring in detail.
Gene
Jul 31, 2013 | Pass & Seymour Pass and Seymour Decorator...
I'm want to install a toggle switch/outlet but have 2 white wires and 1 black. It's a Pass & Seymour 691-WCC6 switch. Can I install this switch?
More information is needed.
Unknown what wiring device was there before, and which wires were connected to which screw terminals.
Wire color is not as important as knowing what wire is for.
If both white wires were connected together before, then they need to be put back same way.
Separate wires. Turn on power. Test each wire to bare ground. Tester lights up on Hot wire. The Hot wire is usually black.
In back of box are white wires twisted together and covered with wire nuts. These are the neutrals.
Test black hot wire to neutrals and tester will light up. If box does not have neutrals, then device cannot be installed to code.
Open following link for illustration of wiring:
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Aug 01, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
How to install Pass & Seymour 5410CC10 sp2 cord switch on a torchiere lamp? Can it be used the same as an sp1 switch?
The cord that runs to your light contains two wires.
The cord switch interrupts one wire.
The second wire runs uninterrupted between wall plug and light.
The photo below is not the same switch as yours, but it shows how one wire is interrupted and the other wire is uninterrupted.
Which wire do you want to interrupt?
Look at the wall plug.
Is the plug polarized, where one blade of the plug is wider?
If the plug is polarized, then one blade is wide and the other is narrower.
Each blade of the plug feeds one of the two wires going to lamp.
Locate the narrower blade, and the wire that comes from that side of plug.
The narrow-blade wire is the wire you want to interrupt when installing the cord switch.
If the plug is not polarized, then choose one wire.
Nov 08, 2010 | Pass & Seymour 5410CC10 Black Feed Cord...
Wiring comination 2 switch, with exisiting light to new bath fan
Hello anonymous,
I am concerned in so many ways... (USA NEC assumed):
FIRST concern:
(after the obvious BATHROOM/GFCI issue) is the
NATIONAL ELECTRIC CODE for wire/device capacity
INSIDE your existing ELECTRIC box...
The CODE requires wires to have space ... aside
from the fact that it is just plain dangerous to
pack wires densely and pack them together tightly...
Then... of course... You have said nothing about the wire gauge/ampacity... (again assuming 14 Gauge/15 Amp)... you will have to calculate the fill for each wire and check the Cubic Inches Plus your device against the ELECTRICAL BOX rated capacity...
That is just the BASICs of SAFETY.
Looking for a diagram of your
"1595" Legrand Pass & Seymour I have failed miserably.
I have found what YOUR switch looks like...
From an old electrician's standpoint...
If you have EACH device wire separately thru
their respective switches...
There should be NO POWER to operate the FAN.
The FACT that there is ... Is highly PROBLEMATICE.
It would seem that a PREVIOUS ELECTRICIAN
has switched the NEUTRAL side of your
old light circuit... Easy to prove with a VOLT TESTER.
I Recommend KLIEN NCVT (non-contact volt tester)
Klein Tools NCVT 1 Non Contact Voltage Tester Electrical Tools Amazon com
A SWITCHED NEUTRAL
poses an EXTREME hazard in a bathroom
(any water) location but is EASY to fix...
Rip it ALL apart and properly configure all the EXISTING WIRES...
Do it right... Be safe.
WHAT ARE TWO BLACK WIRES FOR COMING OUT OF PASS sEYMOUR 1595 SWT SWITCH FOR
Carnac the Magnificent
Apr 30, 2017 | Pass & Seymour / Legrand 1595-2SWT...
Pass & Seymour #5410WBPCC5 White In Line Cord Switch Logo
98 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
