Question about GE Spacemaker JVM1640SJ Microwave Oven
How to remove the vent above the door for cleaning
I just want to clean the vent above the door my microwave is white and the ven looks yellow. I want to cace the vent off but I have no Idea what kind of tool it requiers. Not a torx ,not a phillips, not a square drive. Help!!!
  • GE Master
  • 9,174 Answers
Sometimes they may be dirty and will respond to cleaning, but in some cases, the actual plastic may yellow and the only remedy is to replace it.
The manual just says to take the two screws out, but doesn't refer to their being anything unusual. I would assume they're small Philips.
But if you're unsure of what kind of tool to use, can you post a photo of the screw head and maybe we can tell.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
SOURCE:
Samsung Microwave SMH9187 error message (?) 5E
You can do this without removing unit from wall. First unplug unit. Next remove the two screws on the top of the unit closest to the front. These screws simply keep the up facing vent in place. Next slide the vent to the left (plastic latches on bottom hold in place) to allow vent to be removed. You should now see a single screw above the control panel. Remove it then open the microwave door. Gently slide the control panel up which will disengage the plastic latches on the panel sides. Suggest if you are going to remove the controller and replace take a picture before removing it so you know exactly how to reconnect all the wires.
Aug 15, 2012 | Samsung SMH9187 Microwave Oven
How to replace door for frigidaire fmv156dc
If you remove the vent above the door, a couple of phillip screws hold it on top, it slide off to the left, open the door and pull up on door, look at hinge and remove off of tabs
Sep 03, 2010 | Frigidaire FMV156DC Microwave Oven
Steam got inside door of microwave behind glass. Now there are white spots where water dried. How do I clean the inside?
Look and see if there are screws holding the inside of the door to the outside of the door.
If so, remove the screws and the door should come apart, and may be cleaned.
God bless your efforts.
Jun 29, 2010 | GE HVM1540SNSS Microwave Oven
There are stains in between the glass on the door. How can I remove and clean this?
Hello :
Disassembling the door yourself will void the warranty and may require a service technician to repair any damage or put the door back together. It is recommended that a service technician complete this for you. It is not recommended that you disassemble the door yourself.
Things You Will Need:
Glass cleaner
Soft cloths
Glass stovetop cleaner
Steps to Remove the Glass:
Make an appointment with a service technician to remove the glass from the door.
Use glass cleaner to remove as much of the debris as possible.
For tougher stains and food debris, use a glass stovetop cleaner to aid with removal.
Once the stains and debris are removed, allow the service technician to reassemble the door.
Cleaning Through the Door Vents:
When the glass cannot be removed or is no longer covered by the warranty, there are other, more creative, ways that can be used to clean it.
Long handled cleaner
Bottle brush
Yardstick/ruler wrapped in cloth
Bent hanger wrapped in cloth
Dryer vent brush
Glass cleaner
Soft cloths/towels/long socks
Duct tape (optional)
Steps to Clean Between the Glass:
Some Microwave ovens have small vents along the bottom or top of the door. These vents go in between the glass (and are likely part of the problem with other materials getting in there as well). By inserting a towel on a long-handled stick, you can gently clean between the glass without disassembling the door.First, find the vents on the door if you have them.
It may be easier to remove the door from the hinges and lay it flat on the floor. Many microwave oven doors simply lift right off of the hinges, others will require loosening a few screws first. Replacing the door should be easy to do at the end of the cleaning and will not void the warranty.
Start by choosing a long-handled cleaning tool. There are a variety of options available, so be creative.
Secure a towel or soft cloth (long socks work well) to the handle with duct tape or other strong tape. Make sure it’s well fastened so it doesn’t come off and become stuck in the door.
Moisten the towel or soft cloth with the window cleaner or other cleaning product.
Insert the cleaning tool through the vents.
Move the cloth back and forth to remove the debris from between the glass.
Remove the cloth.
Repeat with a clean cloth until all of the debris is gone.
Replace the door on the oven and enjoy the clear, clean view.
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Whirlpool MH7140XF Microwave Oven
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
WE have a Hotpoint Microwave mounted over the stove and it is not vented to the ouside! It's model #RVM 1435! Can it be vented outside?
yes,
you will need to tzke the unit down
look on the back upper middle
you will see your vent fan
open the cover
pull the fan up
and rotate it 90 degrees, but you will need to install a vent for it
you can also turn it 180 degrees if you on an outside wall and the ven is directly behind the machine
Oct 26, 2009 | Microwave Ovens
Splatters between the screen and the glass on the microwave door
You can find helpful exploded view diagrams for most brands by entering your full model number here.
Those diagrams should show if the screen is glued onto the glass, etc. If so, it makes it harder to clean.
Nov 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cleaning vent
two screws on top will release the vent to remove.
Sep 08, 2008 | GE Advantium 120 Convection/Microwave Oven
Scratches on microwave door
We have an over the range GE microwave and my wife was cooking some pasta on the stove and used the vent fan on the microwave to dissipate the steam and when we were done eating she noticed that the steam from the pasta had gotten in between the glass on the microwave door, how can we get rid of this any ideas.
Jan 07, 2008 | Viking DMOR205SS Microwave Oven
Clean vent
The vent (also known as grill assembly in GE literature) comes off after removing the two screws at the top of the unit and gently sliding the entire assembly to the left about an inch. This will allow the vent to be cleaned of grease, hair, etc., as well as giving some access to the areas behind the vent.
Dec 21, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
911 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
