Question about PIONEERPOS Pioneer MagnusTouch-XV POS Computer Celeron 2.8GHz 15" Resistive Touchscreen 256MB RAM 80GB Hard (DE6AWR000014) PC Desktop
I need screen protectors for my PioneerPOS with a 15" monitor. I still have the one that came on it and it is getting bad.
  • 10,865 Answers
Water leaking at the bottom sides and middle
Of your PC Desktop? Unless your CPU is liquid cooled, you have serious problems.
Dec 10, 2012 | PIONEERPOS 15 Inch M5 PENT-M/1.6 1GB XP...
Gemstar 15" monitor/GM 171-B powers up but nothing on screen
You may have either the DC filter caps problem or the back light inverter board has failed, worst case will be bad lamps assembly. So check for 12vdc on the inverter board, bad caps with leaking/bulging top, bad solder joints.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 29, 2010 | MPC Computers MPC F1760I 17" FLAT PANEL...
Screen is blank
Hello
The issue might be that your monitor is not getting enough voltage to turn on properly.
If the monitor is plugged into a surge protector, remove it and plug it directly into the wall outlet. If the monitor works fine, the surge protector is not allowing enough power thru it for the monitor to work correctly - replace the power strip.
If there is no change, then your monitor is going out.
Dec 03, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Pos won't turn on
reseat all cables inside the system. especially the front panel part.
Mar 24, 2009 | PIONEERPOS Pioneer MagnusTouch-XV POS...
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Dell monitor problem
Disconnect and reconnect both ends of the video cable (while the computer and monitor are both off). Also disconnect and reconnect the power cable. Is the power cable plugged into the same surge protector as the computer? And also try a different outlet on the surge protector for the monitor.
Jul 22, 2008 | Dell E153FP 15" LCD Monitor
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
PIONEERPOS Pioneer MagnusTouch-XV POS Computer Celeron 2.8GHz 15" Resistive Touchscreen 256MB RAM 80GB Hard (DE6AWR000014) PC Desktop Logo
21 people viewed this question
Top PIONEERPOS Computers & Internet Experts
David Payne
David Payne
Are you a PIONEERPOS Computer and Internet Expert? Answer questions, earn points and help others
