Question about Whirlpool Washing Machines
MY WHIRLPOOL WASHER MODEL 3RLSQ8033 WONT DRAIN?
gwshaw71
  • 83 Answers
SOURCE: Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Posted on Nov 30, 2007
  • 110 Answers
check your run capicitor
Posted on Jun 01, 2008
  • 29 Answers
SOURCE: whirlpool front load washer wont drain or spin
Sounds like the pump quit working and needs replaced
Posted on Jun 15, 2009
Maytag317
  • 1136 Answers
SOURCE: My Whirlpool washer won't spin
Hi, It sounds like the coupler has broken. If the motor runs but doesn't do either of these things, here is how to Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on Jul 13, 2009
hiltonjug
  • 612 Answers
SOURCE: whirlpool washer model#lxr9245eq2 wont spin or
Your motor runs in one direction to wash and another to pump and spin. Something is wrong with your motor. either unplugged or a bad motor. I would say a bad motor. Very unlikely to come unplugged
Please rate solution
Posted on Aug 24, 2009
3rlsq8033 wont start
The thermal overload (fuse) is found on the motor for this washer. It is a small black box that has 2 wires going to it. Unplug the washer before working on it. If you have a multimeter you can remove the wires going to the thermal overload and check for continuity between the two terminals of the thermal. If your meter shows an open circuit you will need to change the motor.
Sep 27, 2014 | Whirlpool Dryers
3rlsq8033 whirlpool dryer service manual needed to find the thermostat and thermal fuse
THE THERMOSTAT IS LOCATED ON THE BLOWER HOUSING THE THERMAL FUSE HAS 2 PRONGS AND THE ONE NEXT TO IT IS THE CYCLING THERMOSTAT IT HAS NORMALLY 4 PRONGS UNLESS ITS A THERMISTOR TYPE FUSE IT WILL THEN HAVE 2 PRONGS
Where is the thermal fuse on a 3rlsq8033
It is usually attached in the area of the dryer vent. Remove the back of dryer and look for a white plastic part about two inches long that has two wires going to it.
WASHER WONT DRAIN
Does the washer spin on rinse and drain cycles ok? If it does spin but won't drain, the problem is the plasic impeller in your drain pump. This model is a direct drive unit with a reversing motor that runs one direction for agitate, but reverses to spin the tub and operate the drain pump. So if it spins but DOES NOT drain, it's the drain pump, but if it doesn't spin or drain, than it's probably a lid switch. Also the tub to pump hose or pump discharge hoses may be clogged with something. If your mechanically apt, you can do this repair yourself and save a service charge. The pump runs about 30 dollars or so and is really easy to change out. Check out Youtube videos on Whirlpool washer repairs, they will show you everything to do. Yes, I said Whirlpool, because Roper is built by Whirlpool.
Hope this helps
kcomp1863
Dec 29, 2010 | Roper RAS6233KQ Top Load Washer
My washer overflows. it wont stop putting water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.########) and you'll see a list of major sub-components with diagrams and parts.
(The 110 means that it was manufactured by Whirlpool, you also need to enter the 8 digit model number)
Also see the Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has testing procedures as well as a good description of how the washer works.
It sounds like a defective water level switch or water inlet valve.
See the following for how to release the console and cabinet on these machines in order to get to the switch for testing.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Basically, what happens is:
When the washer is turned on, the water inlet switch is closed allowing water to flow thru the inlet valve. When it senses that the machine is to the level selected by the water level dial, the switch opens shutting the inlet valves.
If the switch or valve is defective, water will continue to enter the machine.
The Whirlpool Service Manual has testing procedures (basis continuity tests with a multimeter) for both the switch and valve.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool super capacity commercial washing machine
Sounde like a bad lid switch . With no model number , can't help you further .
Sep 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool front load washer wont drain or spin
Jun 15, 2009 | Whirlpool CAM2752KQ Top Load Washer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
