the 3rd, 4th and 6th light is on when checking the error code. Does anyone know what this is. Seems to have something to do with filling.
Wouldn't you know it. 1 month past 2 year warranty
error 49. Is a water solenoid. Have a good look at it as it has a similar set of LEDS. Look to see the white coils is smooth and not got any lumps or burns. You have 2 to compare. If you can measure them as below. I got one on Ebay for $40
delivered. Still displayed the same problem. Below is my solution. I didn't ant to
pay for a new controller.
I replaced the solenoid but still had binary 49 LED
code. I chased the circuit through the Motor Controller (brown one in
Australia) GW712.
It was a couple of FETS or Qs in a H drive.
The get fed their +v from the main power rectifier. There is a funny
looking round component called F^ which is a quick blow 1.6 A fuse.
Because my solenoid had a shorted turn on it (bubling to outside
packaging) it had blown this.
I didn't have one instock so I
substituted an ordinary glass 2AG 2.0amp fast blow. You need to remove
the old fuse and solder 2 wires into the holes left these are inturn
soldered to the fuse ends. I used hot glue to hold the fuse clear of
any other components.
You can get slow blow fuses almost
anywhere. In my experience ordinary fuses are the same they always fail
after the components are lost anyhow!
If you are desperately
dirty you could just jump the 2 holes with tinned copper but this could
represent a fire hazard if a solenoid goes again.
We amke
microcontrollers. It is a simple fix and saved me $350. A fuse is 10c
or maybe $1 if you buy them one at a time. Make sure you test the plugs
before you start up. My GW712 read:
1. Each motor winding ~ 35 ohms to any other 2. The lid solenoid ~ 70 ohms 3. Each water solenoid ~ 60 ohms 4.The thermistor ~ 10K ohms
When this fault exists you can empty the water by removing the tube to
the Pressure Xducer and using a tube from your mouth to blow into it
HARD!!! The pump will start and pump it out for you.
To calculate the error code (for what use that is when you can find out)
LEDS indicating wash cycle
X X X X X X X X
128 64 32 16 8 4 2 1
Add the values for each light LED
Was this solution helpful? Show your Appreciation by rating it:
