Question about NAD C325BEE Amplifier
No sound from my NAD C325BEE amplifier
No sound from the amp!
I've checked;
Power supply (OK)
Mute turned off, volume turned up(OK)
Source and speakers connected (OK)
Headphones not plugged in (OK)
No obvious damage
Any suggestions?
  • 88 Answers
Audio ic problem or component around audio ic.. good luck
Posted on Apr 26, 2010
Protection circuit "ON" : no sound
Protection devices tend to come on when the power amp section has a problem. I would like to the devices on the heat sink to the cause.
Feb 24, 2013 | NAD C325BEE Amplifier
Wotcha, i've just taken amp out of storage, has'nt been used for a while cant get volume to work properly the sound goes from speaker to speaker and up and down in volume whilst crackeling a lot as...
One way of proving it ISN'T the amp circuitry is to remove the pre-main jumpers and jack in a source that has its own volume control (or try a CD that starts really low) because this bypasses ALL the amps controls. If it sounds ok (albeit LOUD) I'd suspect oxidized contacts on the controls. Turn it off and vigorously operate all controls a zillion times to wear through it. In mosty cases it's the unused controls that fail because they never get wiped. Maybe a shot of contact cleaner on those you can access.
http://www.overload.it/supporto/643/manuali/NAD-C350.pdf
Oct 15, 2011 | NAD C350 2-Channel Amplifier
NAD C325BEE AMP - no audio. Audio o/p IC's measure ok.
trace the signal into those ic's, if there is input then the outputs aren't working unless of coarse you have no supply to them, then they wouldn't output sound.
May 12, 2010 | NAD C325BEE Amplifier
Hi, i have a nad c325 bee amp and i have a problem with hooking up speakers. I have just the tiniest amount of sound coming out so there's some signal there. I have tried different speakers so i know its...
Before you continue, turn the volume DOWN. If you can't hear it at mid-volume there's no sense in spinning the volume knob higher. You'll only endanger your ears and speakers if you suddenly resolve the switch or whatever is the problem.
Are all sources acting the same?
Check these things (from the manual):
Tape Monitor selected?
Muting?
Headphones inserted?
Jumpers missing between Pre-Out / Main In?
BTW: the manual is available at retrevo.com
Apr 06, 2010 | NAD C325BEE Amplifier
NAD 3150 doesn't play any sound
I, too, have the 3150 and have experienced problems with it. With me the INPUT knob is touchy and needs micro turns sometimes to get both channels to come through. Also, it sounds like the pots are dirty as I get a scratchy sound while adjusting the knob. I have been told that these units are great middle of the road audiophile units. Actually, for the price of a used unit you can't do better. I just had an NAD 2400 THX amp delivered today and am using the 3150 as a preamp. My girlfriend is not feeling well and sleeping in the bedroom, though, and I can't listen to it :( The few minutes I heard of Steely Dan's Cousin Dupree made me bout **** myself (until I got the dirty looks). Sorry I wasn't more help! Goooooo NAD!
Jun 30, 2009 | NAD C325BEE Amplifier
Hi  I have a C325 BEE and it turns off after 15 min What can I do ?
It sounds like the CD player is going into standby mode. When this happens it is usually a power supply issue. Look for bad capacitors or solder joints in the power supply. If you don't know what a bad cap or solder joint looks like, take it to a NAD repair shop.
Dec 12, 2008 | NAD C325BEE Amplifier
Sound cuts off
OK,  That means there's some kind of crazy fault in the temperature sensing circuits. I'm afraid you'll have to take it someplace and have it looked at for a more thorough diagnosis.
Aug 31, 2008 | NAD C325BEE Amplifier
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Sound through one channel
Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
Jun 14, 2008 | NAD C372 Amplifier
NAD C325BEE Amplifier Logo
269 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
