Question about Dryers
My Maytag Performa electric dryer (model #PYE2300AZW) will not start. I went through the troubleshooting guide online, but did not help. Is there a built in fuse that can be checked?
  • 1 more comment
  • pauls woman May 17, 2008
    I have a ohm/volt meter with a red and black probe attached with the dryer plugged in to the wall socket may I ask how to a test for continuity on the thermostat and any other part before making my decision to replace them if they are bad plz help I will read this on sunday 5/18/08 and again on monday 5/19/08 hopefully some reply is given. Again I appreciated your assistance and your website structure....Brenda
  • Anonymous May 18, 2008
    had the same problem today, 5/17/08. won't start. checked filter, checked vent for obstructions, reset fuse at fusebox. nothing.
  • MCCLELLANDAN Aug 05, 2008
    IT WAS WORKING JUST FINE & THEN JUST STOPPED.. IT WILL NOT START AGAIN. I CAN HEAR THE NOISE IT MAKES WHEN I OPEN IT WHILE IT IS GOING. THE KINDA CLICKING SOUND, LIKE IT WANTS TO START, BUT IT WON'T. WHAT COULD IT BE?
    President:
  • Dryers Master
  • 2,651 Answers
Thermostat common problem for this machine ( dryers in general) bad thermal fuse, a result of poor venting usually.. with a putty knife or a screw driver the main top can be "poped" open , theres a clip perhaps 3-4 inches in on either side just under main top and from panel assy, after releasing the clips the top can be flipped back to reveal the heater and fuse are. the thermal fuse is located on the right side of the heater box, and can be tested for continuity. no continuity means is blown and needs replacing. part number LA-1053( about 30 bucks). if the fuse checks out ok the n i would check the heater assy and then the thermostat also mounted right there. simple continuity check for all three, all three must have continuity.
Posted on Mar 24, 2008
SOURCE:
Maytag dryer pye2300azw shut off when drying the clothes i check breaker from house to dryer that's OK it won't turn on back
This dryer is fairly easy to repair.
The thermal fuse is probably blown. Look for air restrictions and a bad blower wheel to be the culprit. When that blower wheel starts slipping it causes the dryer to overheat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 29, 2011 | Maytag PYE4558A Electric Dryer
Dryer stops and Beeps with Error code E60
At MaybeNow online guides are always there to provide technical support to troubleshoot Maytag Neptune MDE6700A Electric Dryer Problems which is free of cost. You can also get Maytag Neptune MDE6700A Electric Dryer, Dryers Help from archived solutions related to repair, maintenance
Dec 21, 2010 | AEG T57800 Electric Dryer
I have a Maytag Performa electric dryer that won't start
you have an open thermal fuse.part no. la-1053,its kinda tough to install,i would recommend a qualified servicer
Mar 06, 2010 | Maytag Dryers
Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
No power to dryer was working fine no warning would not start
Most likely a bad fuse. There is one above the heat element, also may have one on the blower housing. Test with an ohmmeter or bypass. Hope this helps!
Feb 16, 2009 | Maytag PYE2300AY Electric Dryer
No heat from dryer.
Do not buy or use a maytag performa dryer model number pye2300ay at all. I fyou have one unplug it and take to the landfill or scrap yard. They are complete junk and nothing but a hassle. One problem after the other on this model no matter what you do. they are complete trash and a waste of your money.
Nov 24, 2008 | Maytag Performa PAV2200
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Dec 22, 2007 | Maytag Dryers
Dryers Logo
806 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
