Question about Roper RAX4233PQ Top Load Washer
Wont drain or spin
My washing machine got to the rinse cycle than stopped, it is full of water and I can hear it click but it won't drain or spin.
  • 5,911 Answers
The most common cause of the problem you are experiencing is a lid switch malfunction. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 8318084.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If you would like to purchase a Repair Manual to assist you with all your repairs, repairclinic.com has one that you can order on line for about $20. The part number is 1170635. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on Apr 26, 2010
  • 576 Answers
If it will agitate when you turn it back into that part of the cycle, you probably have a bad lid switch. If it won't agitate now either, you probably blew a belt. Good luck.
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
My washing machine wont drain the water out before spin cycle it stops and turns off after wash so when you open the lid its still full of water
Hi just read your posting.Now you said in your posting it does not drain before the spin cycle, but does it drain before the rinse cycle?Does your machine stop and beep and show an error code in your LCD display or if you have the other model a series of lights?Have you tried advancing the cycle to spin and pushing the start button?Please reply with additional information and I can help you track down this fault.
Jun 27, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washer will work on rinse, then stops, won't drain or spin.
most likely the lid switch is faulty .there is a tab on the washer lid that lines up with the lid switch make sure it is lined up and switch is depressed . should hear a click ,if not replace switch.
Sep 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
Washing machine stopped
try lifting the main top up and down and listen crefully do you hear any clicking just before the lid closes??? im assuming not, the lid switch sounds bad. wont drain or spin with a faulty lid switch
Mar 15, 2008 | Washing Machines
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
Roper 7 cycle
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch part number3949247
Mar 04, 2008 | Washing Machines
Roper RAX4233PQ Top Load Washer Logo
223 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
