Question about Whirlpool RBD305PD Electric Double Oven
Code E6 F2 keeps coming up. Oven is not working
How can I get my oven to work?
    Guru:
  • 310 Answers
We repair a lot of control boards for this problem.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Jun 19, 2010
Displaying E6 & F2 code
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 13, 2011 | Ovens
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
I have a whirlpool oven rbs305 and the pannel shuts down and a code comes up E6 and F2 What can be done Thanks
F2 and e6 in combination indicate a cancel key open condition. What this means in layman's terms is that the key-panel Has a problem. If it was just recently cleaned with a wet cleaner, you can try drying the keypad off or even CAREFULLY warming it up with a hair dryer. Don't get it too hot so that you melt anything.
If this does not work, you will need to replace the key panel on the oven.
You can do this repair yourself and should you decide to, please just comment back with the full model number off the tag on the oven and I will give you step by step instructions on how to do it.
Good luck!!
Aug 14, 2010 | Whirlpool RBD305PD Electric Double Oven
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Double oven will not work sometime
Mobley, F2-E6 code is cancel key drive line open. The tech sheet I have on this recommends reseating the keypad connector. It then states to press cancel. If the error comes back within 60 seconds replace the keypad....Catriver..post back.
Sep 16, 2006 | Whirlpool GBD307PD Electric Double Oven
Whirlpool RBD305PD Electric Double Oven Logo
98 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
