Question about Yamaha CDC-585 5-Disc CD Changer
Will not recognize discs
Goes from 1 through 5 then states No Disc, there a grid of #s 1-20
which appears beside the No Disc message.
How do you format a cd
For windows 7:
1.Insert a disc into your computer's CD or DVD drive.
2.In the dialog box that appears, click Burn files to disc.
3.In the Burn a disc dialog box, type a name for your new disc.
4.Click Show formatting options, and then click one of the following formatting options:
-Live File System
-Mastered
5.Click Next to prepare the disc.
and for CD-RW:
1 Insert a disc into your recorder drive.
2 In My Computer, right-click your recorder drive.
The 'Use with DLA' option in the popup menu should have a check mark beside it. If this option is not selected, click on the HELP button and follow the steps in "Using DLA With Your Recorder Drive" before proceeding.
3 Click Format.
DLA's Format dialog box appears. The options available to you will depend on the type of recorder drive you have.
4 Set the options in the Format dialog box.
a ) Type a name for your disc in the Volume label text box.
b ) Select either Quick or Full Format by clicking beside the option you prefer. DLA can perform either a Quick or Full format of your discs.
c ) If you have an EasyWrite CD-RW drive, you will have the option to create an EasyWrite disc by placing a check mark beside Enable EasyWrite. (See Using DLA with EasyWrite Drives for more information.)
5 Click Start.
If you selected Quick Format or you selected Full Format and your drive supports background formatting, you will be able to use your disc within minutes. If not, you must wait until formatting is complete before you can write files to your disc.
I hope this will help you
Jul 30, 2011 | Computers & Internet
Wont read game discs
Hi. Try Cleaning the lens using a q-tip and alcohol. Is there any error message appeared on the screen?
Sep 04, 2010 | Nintendo Wii Console
When I install a movie or game, message states need to install disc or no disc recognized
likely your drive cable is bad or the drive is bad. restart your machine and load bios and see if its shows up in your bios.fi it does your drive is working. and it could be the disc.
Mar 23, 2010 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Jaguar 2003 S Type
1 More info needed for disc fault = what are you trying to do to make this disc message appear?
2 The car picture is the dsc switched off - but this message should disappear if the ignition is turned off and on again as the dsc is on by default. If this dsc message keeps reappearing then you may have a fault in braking or sensors that is triggering this message - get it investigated.
Apr 21, 2009 | 2003 Jaguar S-Type
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
Cyberhome DVR 1600, where can I get the firmware update
Hi there
The best bet now the company has gone bust is trawl through the forums to see in anyone has a firmware upgrade saved and available for download. Here is a good start.
http://www.avforums.com/forums/index.php
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Cyberhome DVD Recorder - DVR1600
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Dvd component mal-functioning
Could it simply be your DVD reader is broken?
Jan 06, 2008 | Panasonic PV-DF2702 27 in. TV/VCR/DVD...
Yamaha CDC-585 5-Disc CD Changer Logo
20 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
