Question about Compaq Presario FX700 17" CRT Monitor
Powers up screen is black, will work on external moniter
  • 732 Answers
Atomikhound, May need to find correct drivers for this unit. Try search at HP website using the unit's product number on rear of the monitor. What is date of manufacture on this unit? It seems that this monitor only works with a Presario 4800 series desktop computer for which it was custom designed for. The article I read at "Epinions.com" said it should be used as a boat anchor if you can't get a copy of original 48xx system restore disks that have the special "drivers" needed for it. Good luck. 12fixlouie
Posted on Apr 27, 2010
3 Suggested Answers
SOURCE: i hooked up this moniter turned on the power and nothimg black
My Dell monitor is showing odd splotches of colored bars.....turquoise bars and pink bars. What is causing this?
Posted on Apr 21, 2009
SOURCE: The moniter blacked out, blue
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Posted on Mar 27, 2011
HP laptop wont start up or wont connect to moniter
If you plug the VGA external lead in before powering the laptop up. If nothing on the screen and because the fan is running hard, there may be a GPU issue caused by over heating. The GPU may need the solder removing and leaded solder replaced to get it to work again. A specialist job!
Dec 11, 2013 | Computers & Internet
My aspire 5920 screen is black and will not work on a external moniter either.
Well, i cant tell you what is actually wrong with your tv but, i can tell you how to fix it. You see my tv does this a lot. Here are some ways that might help you: 1. have you tried leaving the tv off a whole day? 2. did you buy a new one yet?...I'm sure that there are a lot of other ways to solve it but, i could only think of two. I hope that i have helped you with your problem. Have a nice day fixing your tv.
Apr 21, 2013 | Computers & Internet
When my computer is on the moniter is blank.
The monitor only has one cable and it is keyed to fit one way. They are always located under the top bezel. Should have roughly 20 pins and the wire will flow up into the display. If the screen is very very dim (look carefully) then your inverter board is most likely bad these run 40-120 dollars depending on model and are located along the bottom edge of the display itself. If the screen is completely black, try plugging an external monitor into your laptop (make sure you try toggling the display mode) [typically Fn + F7 or whichever says LCD or has a monitor icon.] If the external monitor works then your screen is most likely the problem and will need to be replaced. If the monitor does not work, the motherboard needs to be replaced. You will be hard pressed to find any schematics for motherboards but you could dis assembly the the laptop and easily check for descended capacitors, burns and the light though most of the time I doubt you will be able to see the damage.
Best of Luck
Jan 24, 2012 | Computers & Internet
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Connect AC power.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Black screen
if you dont have any view on external monitor too  there so 2 reasons for.  1 is mainboard (graphic chip) 2 is LCD data cable that comes from Mainboard and goes to LCD.  need to go to Service
Apr 17, 2009 | Compaq Presario Notebook
Acer 9300 black screen at start, tried some things, didn't work.
The cables to the LCD and the Inverter board may not be hooked up correctly...
I have manual, I can email it to you. joediaz911@comcast.net
Apr 05, 2009 | Acer Aspire 9300 Notebook
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
Fujitsu siemens 8830
check to see if lid switch is functioning correctly if possible.
if **thing seen,** change ,inverter board needs replacing.
you've tried changing moniter so it isnt cable connections internal or external.
you're **t hearing any beeps so it isnt video,mem or hd.
Mar 01, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Compaq Presario FX700 17" CRT Monitor Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
