Question about Apple Power Mac G5 Desktop
My first Mac: a used Powermac G5 and I cant connect to internet
I have a PC that connects just fine. Even when I unplug the ethernet cord from my PC and plug it directly into my Mac, I cannot get internet service. This is my first Mac. Am I doing something wrong?
  • Apple Master
  • 739 Answers
Hi Christine.
With a cable plugged in The Mac should automatically connect.
Try this. Leave the ethernet plugged into the mac and shut down the mac. Power it back up and see what happens - does the light on the router (1,2,3 or 4) come on to signify that the mac is talking to the router?
If not then I would think that there may be a problem with the ehtenet port on the Mac.
Also, open system preferences and then select network. Make sure ethernet is selected and then click on the TCP/IP tab. You should see a bunch of numbers listed - starting 192.168. or 10.0. and a line with lots of 255. If you get these and the top number differs from the bottom number then you should have a connecttion. If on the other hand you only have one line of numbers and it starts 169. then the mac is not talking out of the ethernet port at all.
If that is the case you should get someone in to look at it.
Post back and let us know what happened.
Posted on Apr 26, 2010
Power mac g5 shows terrible damage in tower from leaking they swear mom board is fine but its hard to believe. are any of the other parts usable for a g3 to g5 imac or g4 powermac or emac
None of the parts are usable in any other machine.
The coolant from a liquid-cooled G5 PowerMac is toxic. If your G5 is leaking, disconnect the power cord IMMEDIATELY. Flush any skin exposed to the fluid with water for at least 15 minutes.
If you want to glove up and extract your hard drive from the machine so as to save your data, do it carefully. Other than that, my recommendation is to bag up the unit and handle it responsibly as toxic waste, using the same guidelines your area uses for antifreeze.
Oct 31, 2010 | Apple iMac G4 Desktop
I have an iMac g5 and an eMachine. I have internet on the iMac and I need to get it to the Windows computer. I have TONS of cords and like 5 wifi roughters. I just need to know what to do inside...
just connect both computers to the same router/hub. if mac is working then windows should work as well. on a wired network in windows xp and beyond, there is no set-up required. if it is not working, then perhaps you using a crossover cable (meant to connect 2 computers directly) instead of a regular ethernet cable.
Sep 30, 2010 | Apple iMac G5 Desktop
Apple mac G5 freezes when booting up.
Try unplugging all Firewire/USB devices. Also, unplug the power cord from the computer. This resets the logic board. If that doesn't isolate the problem, put your Original system CD that came with the computer and hold down the C key. Boot up and run Disk Utility. Run the repair disk and then repair disk permissions. Reboot and try booting your system again.
Jan 03, 2010 | Apple PowerMac G5 Dual Mac Desktop
My apple aluminum keyboard not working with Macbook Air
try to connect your keyboard to the mac air while mac book is connected to internet (by wifi) then update your programs (apple menu - update).
Dec 22, 2009 | Apple Computers & Internet
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
Lost connect to all servers, internet and email
Create a new user account on your machine and use it. Your account might have gone bad.
Jul 02, 2009 | Apple Power Mac G5 Desktop
How to replace the power supply on a powermac G5
I would be very cautious doing this, if you are not an Apple tech. You can damage the connector for the G5 Processors, and render the machine un-usable.
You have to remove the RAM and Processor, then remove the two power connectors that connect from the power supply to the logic board. On the bottom, underside of the chassis, there are four screws. Remove them, then you can tilt the power supply out of the bottom of the unit.
Replacement, is just the reverse.
Apr 17, 2009 | Apple Power Mac G5
Connect internet via ethernet
to use dhcp with several computers, you need to have a box that allows the dhcp mode and which is configure to goes on
Jan 17, 2009 | Apple Power Mac G5 Desktop
Cant connect my G5 to the Router to get internet
two things to consider. There are two different types of Ethernet cables out there. Perhaps you have a one way cable for the second one. To test this, unhook the working cable from the mac that gets internet and then hook that one up to the one that doesn't get it. See if it sees the network after a minute. The other issue might be in the Operating System. You might need to make sure that they are both up to date with all of the latest updates installed. (I know, hard to do with out an internet hook up.)
Lastly, make sure you are plugging in the cable to the right place on the back of the router. Seems silly, but some of the best have accidentally put it into a link plug to connect several routers rather than an actual Ethernet plug.
Dec 22, 2008 | Apple iMac G5 Desktop
Apple Power Mac G5 Desktop Logo
105 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
