Question about Logitech QuickCam Chat Personal Web Camera
Web cam when I start windows media center it tells me a camera has been detected and I need to reassign it to disk drive not a usb for it to work properly, How do I do this
  • Ekse May 11, 2010
    It asks you to assing your webcam into a diskdrive for it to work properly?
    Please recheck the error message, that cant be right.
  • Logitech Master
  • 13,434 Answers
Try reinstalling the camera software you can get the newest sofware from logitech website :
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en
Posted on May 02, 2008
SOURCE:
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
Media center receiver service
You need to reinstall Windows.
Aug 16, 2008 | Computers & Internet
I have a My Book which has a broken USB jack. I removed the drive from the case and would like to know if it's still possible to access the data on it. Smart tests detect the drive as OK, and it ran...
If the SATA-to-USB converter is working properly, then Disk Management should show the device, assuming that the disk-drive itself is working properly.
Dec 27, 2010 | Western Digital My Book Essential...
Western Digital USB powered WD600U017 drive Does not appear to be spinning up. This drive has been in use for 2 years When plugged in the drive makes 3 beeps 2 low ones followed by a higher one. It...
The first thing I'd recommend is to check Disk Management, to see if the computer is detecting is as a hard drive. ( Right click on my computer, hit manage, and under Storage, select 'disk management').
From there you'll be able to see how it's detecting the hard drive.
Even if Device Manager detects it, if Disk Management does not, you know it's not being 'properly' detected.
From Disk Management, you can format the drive, or reassign a drive letter (if needed).
I've had a similar issue where the problem was the power connector to the hard drive. If you have important data on the hard drive, you could open the external case, and attach the hard disk with a separate usb device, such as http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=3276554 . Good Luck.
Nov 16, 2010 | Computers & Internet
I just transfer some very important files on my book essential drive.The first day it works fine but now it wont show the icon,but when i go to device manager,it shows as INITIO COMBO DEVICE CLASS. can...
jayvely
Sometimes the drivve letter that gets assigned to the drive will get bumped by another device. The links below will help you check Disk Management to see if you need to reassign the drive. Also if you did not get a proper disconnect from the computer you may want to try to connect the drive to another computer to see if it will detect.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 13, 2010 | Western Digital My Book Essential 1TB...
WD My Book not displayed in windows explorer as drive letter
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Sep 24, 2009 | Western Digital MY BOOK HOME 1TB EXT...
My computer worked properly. but at once my IDE devices started giving troubles. my 2 IDE devices are not detected at the start up.
The BIOS will have trouble detecting faulty IDE devices, eg the hard disk etc.
To check if the IDE devices are faulty, connect the hard disk to an USB hard disk adapter and plug it into a working computer's USB port, if the computer detects it as an external hard drive and you can open the folders and files then the hard drive is OK and the fault is the disk controller. If the hard disk is not detected then it is faulty and a new hard disk is needed, Windows installed on the new hard drive together with the device drivers and your programs to get an fully functioning computer again.
Sep 01, 2009 | Intel D865GBF Motherboard
Not Detected on PC
I found this on this site. in case you havent seen it. It worked for me. Try this:
When I disconnected my backup drive and plugged in a USB drive the other night, my Windows drive letters got all wonky. D: became G: became F: became H:, and a bunch of my shortcuts didn't work anymore.
But it's easy to reassign the drive letters of your choice to add-on disks in Windows. Microsoft says you should log on as an administrator, and from Administrative Tools in Control Panel:
Double-click Computer Management, and then click Disk Management in the left pane.
Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths. Of course things can get wacky if the disk is in use - by your computer or another on the network - so proceed with caution, you drive alphabetizer, you.
How to change drive letter assignments in Windows XP [Microsoft TechNet] Read More: Windows, Hard Drives
Jan 29, 2009 | Western Digital WD Passport 250GB Portable...
Ipod touch is not detected in my system
Start with this troubleshooter
if you need more assistance, let me know.
http://www.apple.com/support/ipodtouch/troubleshooting/ipodtouch/
Mar 25, 2008 | Apple iPod touch
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Logitech QuickCam Chat Personal Web Camera Logo
205 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
