Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tiller loose power when tilling - Troy Bilt Pony 6.5 Hp Rear Tine Tiller
  • 10,865 Answers
Your problem is most likely due to some crud in your carburator. Get a can of carburator cleaner which you add to your fuel. Run a tank of the treated fuel through the tiller and it should be ok. IF not, you will have to rebuild or replace the carburator. Joe
Posted on Apr 26, 2010
I have a Powermate tiller that starts good but looses power and stalls when I start to till. I have fresh fuel, spark plug looks good, and air filter looks like brand new.
Change the plug and filter anyway. Cost is minimum and is the first thing a small engine shop will do. If this doesn't fix it check your belt on the drive to the tines. Could be to tight.
May 12, 2012 | Garden
The rear tine seals are leaking ive taken the bolts out but the tines will not come off what can i do
You could try putting the tiller to use, preferably where it will have to work hard to till the ground it unsuccessful you may need a torch and some good old fashion luck to loosen tines from shaft. Now consider this; if the bearings are worn so that the shaft is loose new seals will not hold up and you will risk doing further damage to the worm gear located on rear shaft and possibly other damage to your transmission from contaminated oil.
Mar 04, 2011 | Troy-Bilt Pony Garden Tiller
Mtd.tiller,pwer on wheels,but no power on tynes
If you have drive power but no till power the problem will for sure be in the gearbox. What is the model number of your tiller?
Jun 17, 2010 | Mtd Products Yard Machines 158CC Tiller
Engine looses power, then speeds up, then looses power again
This sounds like the little fellow is getting hot. Are you using a good oil in the fuel don't skimp on that oil use the best you can find and get a new plug to sounds like the oil is killing your tiller.
Aug 02, 2009 | Mantis Tiller
Tines do not rotate with any power
what kind of cultivator??? sounds like oil on the cutch or broken clutch need more info.
Jul 13, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Troy bilt jr tiller
If you try to till too deep, this is what will happen. You have to start shallow and and gradually lower the depth on subsequent passes. That will even happen on my 'Horse' model if I try to go too deep too fast.
May 25, 2009 | Troy-Bilt Pony Garden Tiller
Yard man tiller model#21a240m029
You don't use the wheels when your tilling!
Apr 19, 2009 | Mtd Products Yard Machines 158CC Tiller
WHEN TILLING TILER WONT MOVE FORWARD WHEELS JUST SPIN. HAVE TO PICK UP ON HANDLE TO GET IT TO MOVE.
Usually this means you are trying to dig too deep in one pass. Try setting the depth such that your first pass only scratches the surface, dislodging grass, etc. Then, on successive passes dig 1-2 inches, this will prevent the tines from "biting off more than they can chew" and holding back the machine. It will take about 4 passes to till one tiller width in "loose"(garden) soil and possibly more elsewhere. Hope that helps.
Mar 13, 2009 | Mtd Super Bronco Rt Tiller
Tiller usage
Power tillers are used for breaking up the soil. They improve conditions for new plantings, develop gardens, weed, and reseed lawn patches. A power tiller takes the toil out of large or difficult projects. Below you will see the three main types of power tillers available. Choosing between them generally depends on the size of the area you wish to till and the type of soil in your area
Aug 27, 2008 | Mantis Lawn Dethatcher Attachment
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
145 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
