Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
No sound from my tv speakers. mute is off and exteral speakers are off. There is only TV and cable box on. I can see the volume going up and down, but there is no sound 52 bravia w series
  • 178 Answers
  1. hook up your cable box to another TV check it.
  2. reset the TV by press and hold the [^] on the remote and press [power] on the TV.
  3. Do software update.
  4. replaced the main board,
Posted on Apr 27, 2010
Testimonial: "Thanks - actually it was my cable box audio set up that needed adjustment - volume level had to be switched from varable to fixed(Optimum). "
My t v has no volume
Do you see the volume indicator moving when you press the vol up/down?
Could the internal TV speakers have been turned off? This is done when using a sound bar or a AVR (Audio Video Receiver) aka Home theater
Mar 03, 2015 | Televison & Video
How do you un-mute tv settings
Try pressing the mute (speaker symbol with diagnol line) or just press up/down volume button
Sep 08, 2014 | Televison & Video
Olivia tv has no sound but see picture what does this mean?
  • Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2
    Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3
    Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • May 07, 2014 | Vizio L32 32 in. LCD HDTV
    No sound
    Make sure your not using spanish audio programming make sure its not muted depending on the tv some tvs have speaker off and the audio would pass through the rca out.. If your using equipment to view tv make sure your audio in is plugged in.. Change channels and see if you have audio than
    Mar 25, 2014 | LG 47LC7DF 47 in. LCD HDTV
    Muted my sharp le 810 and now i can't retrieve the sound
    If you push the volume button on set does it show on screen?
    My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
    Does not sound (pardon the pun) like a circuit repair but like an error.
    Check all audio settings or options first in the set and then the box.
    Mar 21, 2012 | Sharp Televison & Video
    We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
    Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
    Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
    I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
    It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
    Jan 09, 2011 | Sharp Televison & Video
    My view sonic monitor has no sound
    Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
    Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
    No sound on sony tv
    Your set may have a choice of audio sources and outputs in the basic (initial) setup since it is not uncommon to mute the internal speakers and get your sound from a home theatre system or receiver. Also, if you are using S-video connectors between converter and set, there is no sound path, this is video only, and you will have to add a couple of cables, likely with RCA connectors, between the two.
    For reference: Audio cables: Red=right channel, White=left.
    Sep 06, 2009 | Insignia Digital-to-Analog Converter for...
    NO SOUND
    Unplug the power to the tv for couple of minutes; replug and should have sound!
    Jul 19, 2008 | RCA F32665 32" TV
    Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
    479 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
