Question about Pool & Spa
Low/High Switch wiring for Hayward Superpump
This was a direct replacement for the 2-speed Hayward superpump that we had installed when the pool was built. Nothing different other than having to figure out the low/high speed switch yourself and a change in the input pipe size from 1.5'' to 2.0''. Both motors are AO Smith units, but again the wiring panel is slightly different. I do not have any timer in the system.
Here's what I have:
50amp, GFI 230v, 3-wire connection (2 hot and 1 grd)
Wiring Panel on motor:
Terminal 1
Terminal 2
Terminal 3/4
Grd is separate
Each have a screw and male connector, 3/4 has an additional male connector
Currently wired according to wiring diagram on motor:
115v---------Terminal 1
115v---------Terminal 3
Grd----------Grd
Low/High Swt
White--------Goes inside to motor
Black--------Terminal 3
Yellow-------Terminal 4 (my guess, diagram shows just line with no connection point)
I found a post on a pool site where they have the same pump but have their 230v connections to Terminal 1 & 2. They have high speed only and the same problem of figuring out how to wire the low/high switch.
I understand that you are not reducing voltage to the pump via the switch but are actually changing to a different winding. The switch wiring is baffling to me. I can only get low speed from the pump now which I believe is going through the white/black connection of the switch, flipping the switch to the black/yellow connection shuts off the pump.
  • Charles Rutherford
    Charles Rutherford Apr 26, 2010
    The motor comes with the L/H switch built in and the old motor worked just fine with the same kind of switch in it but it was wired differently than the new motor.
    I believe you are correct that #1-Common, #2-High, #3/4-Low. I just need to figure out how to switch between the Low/High terminals with the current switch. I will post the motor number later this afternoon.
    Charles Rutherford Apr 27, 2010
    Thanks for the help but after diagramming possible solutions to the wiring I was able to come up with the solution. Without getting long winded, the Lines 1&2 do connect to Terminals 1&3/4 then the switch wiring is Black to Terminal 3/4 and Yellow to Terminal 2. This allows you to switch from low to high with the SPDT switch.
    President:
  • 1,378 Answers
I do not read anywhere that you have a 230V DPDT switch which you will need in order to select the high or low speed. You will have 6 terminalas on the switch. Line connections usually go to the middle set. Put put sides of one pole to the common terminal and put one of the other posts to the hi and the other to the low terminal. I prefer to use am on-off-on switch so the switch in the middle turns off the pump. Flip it one way for hi and the other for low. If you post your stock number from the two-speed motor I could give you a more accurate diagram if you need it. Generally, 1 is common, 2 hi and 3/4 low.
Posted on Apr 26, 2010
  • John Prohaska
    John Prohaska Apr 26, 2010
    Sounds like they are using a SPDT switch instead of a DPDT. Not the best way but ok...
    One line lead needs to be the switch common. The other two switch leads are then are the hi and low. Hi to 2 and low to 3/4. The reason you are only getting a low speed is your line lead to terminal 3. If you moved it to 2 you would have hi only. You need the switch to take the 2nd hot lead and alternate it from hi to low based on switch position.
    That said, you may have to locate where the switch's white wire goes in the terminal board. It may be on a double-prong quick connect post and that would be where you put your 2nd line lead. Then the yellow lead would go to 2 to be the hi speed lead.
    For a specifc answer I would still need the motor number and also the switch if you have one for it.
  • John Prohaska
    John Prohaska Apr 27, 2010
    Do you have the numbers yet? I would appreciate the chance to give a more accurate answer in the hopes of an improved rating...As a volunteer expert I take pride in my high approval ratings.
Pump works on low speed only
Could be wire is loose on high speed terminal. Look at trouble shooting guide at http://www.hottubworks.com/
Oct 13, 2012 | Hayward SUPERPUMP 2.0 HP, 115/230V
I am replacing a 230V single speed AO Smith with a hayward super pump 230V two speed of proper size. Out of the super pump are two purple wires, a black wire and the green ground wire. The superpump has...
It sounds like you need to purchase a 2-speed switch for the rear of your super pump. With your current set-up, you will only be able to connect either a low speed, or a high speed and not both.
If you confiirm this via my e-mail, I can further guide you as to what you need to do next. If you just want to connect the high speed for now I can also help with that. By the way, are both purple wires solid in color, or does one have a black stripe on it?
If this post has helped you, please take the time to vote positively for me after reading this.
Thanks,
Adam
Oct 26, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
I am replacing my Hayward 1 HP superpump. The old pump had the 230/115 conversion plug on line 1. The new pump has it on line 2. Do I jusst connect the 115 v(hot) wire to line 2? That would be oppisite of...
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
Oct 19, 2009 | Hayward 1.5hp 230v 2 Speed Uprated Super...
Have hayward 2speed pump and cant get speeds to change ontime clo
If I am following your description correctly it sounds like the booster is tied to the wrong clock...You want the booster to run with the high speed which is 'the other' timer it sounds like.
Sep 11, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Wiring difficulties during hookup
The side of the motor will have a diagram showing how to connect the wires for common high and low speeds. There should also be a voltage selector device on near the terminals you connect your line wires to. Set that device to the 115 setting and you should be all set.
Jul 14, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
I'm need assistance wiring my hayward 2 speed super pump up with my pool timer. the pump is working now but it's running real hot and making alot of noise.
You may have a faulty bearing ... causing the noise. The pump is actually water cooled. Do you have 2 inch line for your 2 HP pump? Small pipe makes the pump work harder. If your lines are smaller, you may want to consider a smaller pump.
the motors will run pretty warm.
Run your pump on high for best results.
If you are using a timer ... you will need a double pole switch to turn it off if it is setup for 220 VAC (which it should be, for most econimical operation)
Jul 08, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Pumps Capacity?
# Aboveground filter systems and small inground pools (under 10,000 gals) should use a Low Head pump like a Maxim, or Dynamo or Power-Flo. # Pools from 10,000-20,000 gals can use a Medium Head pump like a SuperPump, a Pinnacle or Cygnet. # Pools over 20,000 gals could possibly use the High Head pumps like, Super II, Challenger, Ultra-Flo or the Sta-Rite pumps. # Pool/ Spa combos with at least 3 lines influent and 2 - 3 back to the pool, 2" plumbing may be able to handle the Ultra High Head pumps like NorthStar and the WhisperFlo
Aug 27, 2008 | Hayward 2 Hp Max-Flo Swimming Pool Pump...
Pool & Spa Logo
1,369 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
