Question about InFocus VGA Cable - 15 pin male-male, 4 meter Multimedia Projector
I'd like to know how to assembly a 10 wire isolated cable with a VGA connector
  • 36 Answers
Pinout of the VGA conector.
http://www.pc-control.co.uk/vga_connector.htm
Posted on Jun 18, 2010
Video on my toshiba L455=s5009 comes on for a few seconds then blacks out
From your brief diagnoses stated, it sounds like a bad Video Cable.
The Video Cable routes from the motherboard, across one edge of the Fan Assembly, and under the left Hinge assembly,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/big-body/laptop-disassembly-19.jpg
With just the usual opening, and closing of the laptop, the Video Cable's sheath may be damaged. This means the tiny wires inside the sheath may be damaged.
(Stretched/Broken)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/laptop-disassembly-1.htm
http://www.laptoprepairparts.com/html/details.asp?ref=1860&category=cables
Or it may be the screen Inverter that is damaged, or going out,
http://mcccomputers.com/shop/lcd-inverters/3666-new-toshiba-satellite-l455-s5009-l455-s5045-lcd-inverter-pk070006t20-k000087330.html
Or the LCD screen assembly.
Could be the graphics chipset.
Diagnose.
1) Laptop OFF, monitor OFF, connect an external VGA monitor to the laptop's VGA connector, on the back of the laptop.
[ RBG (Monitor) port ]
You can use a CRT monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable, for the external VGA monitor.
[ Example of a VGA cable, and a VGA port (Connector),
http://en.wikipedia.org/wiki/VGA_connector ]
Turn the external VGA monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the external monitor should show the display, also.
IF not;
1) Press, and hold down on the Fn key, and simultaneously tap on the F5 key. (The F5 key is the Display toggle-over key)
Not showing on the external VGA monitor? Perform the above procedure again.
There are several display options.
External VGA monitor also show the same symptoms?
Bad graphics chipset. Replacing the motherboard is the most cost effective method, and easiest method.
External VGA monitor does Not show these symptoms?
Problem is the Video Cable, or screen Inverter, or LCD screen.
Due to movement of the LCD screen, which means movement of the Video Cable, my money is on a bad Video Cable.
(A Video Cable can be unplugged partially, real easy, on the back of the LCD screen.
It MAY look plugged in tightly, but may not be.
It can also be unplugged real easy when assembling the Display Assembly, to reinstall back on the laptop )
Check the Video Cable's wires with a multimeter. Perform a continuity check of all wires in the cable. (Multimeter set to Ohms)
Have an assistant also gently wiggle the cable, as you are testing. See if there is an intermittent break, due to a stretched/broken wire.
Or just buy a replacement Video Cable, and use it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 04, 2012 | Toshiba Satellite L455-S5009 laptop
Heater only works on #1 setting after I replaced resitor pack
resistor is working but switch is bad. You can get a new switch from autozone for $20. Here is autozone procedure for pulling the control panel. Let me know if you have questions.
  1. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  2. Remove or disconnect the following:
    Audio unit Instrument panel console bezel retaining screws
  3. Pull the instrument panel console bezel forwards and disconnect the electrical connectors.
  4. Detach the temperature and air distribution blend door Bowden cables from the climate control assembly.
  5. Remove the climate control assembly.
To install:
  1. Install or connect the following:
    Climate control assembly Bowden cables to climate control assembly Climate control assembly electrical connectors Instrument panel console bezel and securely tighten the screws Audio unit Negative battery cable
Dec 16, 2010 | 2000 Ford Focus
I need to change the starter in my 2001 dodge neon
The starter is located under the car where the transmission and engine meet toward the front of the neon. The starter actually bolts up with face toward the transmission. You must get the car up on ramps or on a hoist to see the starter. This is just a general method; it is very hard to give words to describe some of the steps without pictures. Removal: Disconnect and isolate the battery negative cable. Raise vehicle on hoist. Remove starter bolts. Remove starter assembly. Disengage latch and remove solenoid connector from starter assembly. Remove battery positive connector from starter assembly. It is not necessary to remove the alternator output lead from the connector. Installation: Clean corrosion/dirt from the cable and wire terminals before installing wiring to the solenoid. Attach battery positive connector to starter. Ensure alternator output connector is snapped into the battery positive connector. Tighten the captive nut to 10 Nm (90 in. lbs.) . CAUTION: It is critical that the alternator output terminal be connected to the battery positive terminal of the starter solenoid, for proper operation of the charging and cranking systems. Install solenoid connector to starter. Ensure that latch is fully engaged. Position the starter face into transmission housing. Start bottom mounting bolt and thread in until bolt is snug. Attach ground cable to upper starter mounting bolt. Ensure the proper starter alignment before tightening the starter mounting bolts to 54 Nm (40 ft. lbs.) torque. Lower vehicle and connect negative battery cable.
Jul 13, 2010 | 2001 Dodge Neon
Where is the starter located in a 2000 plymouth neon
Removal:
  • Disconnect and isolate the battery negative cable.
  • Raise vehicle on hoist.
  • Remove starter bolts.
  • Remove starter assembly.
  • Disengage latch and remove solenoid connector from starter assembly.
  • Remove battery positive connector from starter assembly.
  • It is not necessary to remove the alternator output lead from the connector.
Installation:
  • Clean corrosion/dirt from the cable and wire terminals before installing wiring to the solenoid.
  • Attach battery positive connector to starter.
  • Ensure alternator output connector is snapped into the battery positive connector.
  • Tighten the captive nut to 10 Nm (90 in. lbs.) .
  • CAUTION: It is critical that the alternator output terminal be connected to the battery positive terminal of the starter solenoid, for proper operation of the charging and cranking systems.
  • Install solenoid connector to starter.
  • Ensure that latch is fully engaged.
  • Position the starter face into transmission housing.
  • Start bottom mounting bolt and thread in until bolt is snug.
  • Attach ground cable to upper starter mounting bolt.
  • Ensure the proper starter alignment before tightening the starter mounting bolts to 54 Nm (40 ft. lbs.) torque.
  • Lower vehicle and connect negative battery cable.
Dec 14, 2009 | 2000 Plymouth Neon
How do i remove the starter of my 2000 neon
The starter is located under the car where the transmission and engine meet toward the front of the neon. The starteractually bolts up with face toward the transmission. You must get the car up on ramps or on a hoist to see the starter. This is just a general method; it is very hard to give words to describe some of the steps without pictures.
Removal: Disconnect and isolate the battery negative cable. Raise vehicle on hoist. Remove starter bolts. Removestarter assembly.
Oct 30, 2009 | 2000 Dodge Neon
I just bought a cat5 cable and to covert to vga male and famle head . But i have no clue which pins to solder together because cat5 has 8 cores , while vga has 15 pins or so can you help
I'm not exactly sure how you expect to use a Cat 5 cable for VGA video (Takes 12 wires last time I looked) but here is how the cable connectors are wired
SVGA (35-37 KHz - 800x600) 15 pin sub D:
6
1 Red (Analog) 6 Red Return 11 (ID0) GND (Color) 11. . . 1
2 Green (Analog) 7 Green Return 12 (ID1) NC (Color) . . .
3 Blue (Analog) 8 Blue Return 13 Horzontal Sync . . .
4 Not Used 9 Not used 14 Vertical Sync . . .
5 Ground 10 Ground 15 Not Used . . .
15 10 5
Jun 22, 2008 | Computers & Internet
13pins "from the inside monitor" "to the VGA 15 pins connector
hai dear,
i checked your problem and found that you open the cover of monitor and you find the two jack of data cable in main pcb and neck card( 2 connector of data cable).plz you cut the connector of data cable and you will find 8 wires in connector.related red(invild extra ground),green(invild extra ground),blue(invild extra ground),black gnd,white,orange,gold(extra gnd) and now you cut the red wire, you will find two wires.so you refix the main red wire pin no-1 of connector and red gnd pin no-6,green main wire pin no-2 and green gnd pin no-7,main blue wire pin no-3 and blue gnd pin no-8.check for the horizental sync and vertical sync wire you should go in main pcb which invild the other connector. there is present in print, h- sync(two wire of h- sync main wire in pin no-13 and other pin no-5) and ver.-sync wire in pin no-14.first you will check the whose h-sync and vert-sync in color and now finally other wires will fix any pin of connector.
Apr 03, 2008 | SAMTRON 55V 15" CRT Monitor
13pins "from the monitor" "to 15 pins VGA connector"
You will have wires of 7 colours. Solder it as per the data below...
White 7
Red 6
Black 10
Yellow 9
Blue 12
Green 1
Brown 13
The pins are numbered as follows
4 3 2 1
8 7 6 5
12 11 10 9
13
Apr 02, 2008 | SAMTRON 55V 15" CRT Monitor
Wire a vga cable in backin
in vga connector their are 15 pins .u have to solve this problem u have a digital meter to cheack contunity of the pins. if there is old wire is connected on crt board .first u cheack 0 omhs continutey to 1 pin to 15th pin. then u sold ur new cable
Mar 03, 2008 | Belinea 10 17 15 17" LCD Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
75 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
