I have a Maytag A206 washer. When it fills up with water , it overflows. What is causing this? Thanks
  • Steven Humphrey Apr 26, 2010
    Thanks-about what I figured but wanted to double check myself.
    President:
  • 1,218 Answers
Good day,
Depends on how you stop the filling process. If you have to shut the water at the supply by hand, then it is a defective dual water water valve and needs to be replaced.
If you can shut the water off by turning the machine off, then it is either the water fill switch or the plastic hose that connects the fill switch to the bottom of the tub.
The plastic hose could have come off, is cracked and leaking or the fitting on the bottom of the tub is plugged up.
If it seems to be the last item. Fill the tub partially, remove the hose from the fill switch, and blow into it to test to see if it is clear.
If it is O.K. you will hear a gurgling sound coming from the tub.
Posted on Apr 26, 2010
Water will not turn off
see this causes and fix it. God bless you
Water Inlet Valve If the washer is overflowing and power is shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Low Water Pressure from House Supply If the washer is overflowing the water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the pressure is lower, the valve may not close fully when the power is shut off. This results in the valve leaking water into the washer and causing it to overflow.
Oct 16, 2012 | Maytag Washing Machines
Maytag Neptune TL washer overfilling
yes i would agree the water valve is defective as if unplugged it should close,but also sounds like a pressure sensor or pressure hose problem that is also defective too due to the fact that it should at least start the wash cycle even though the water doesn't stop filling,so also it could be the central control unit,pressure switch or pressure hose
May 07, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Lost the manual for my maytag performa washer A206. How do I access the drive and pump belts ?
The A206 is an old style washer. They are accessed by tipping the machine back against the wall. They are easilty replaced, come as a set...replace them both!
Kelly
Mar 22, 2011 | Maytag Washing Machines
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
I have an old maytag model #LA712 top loader. Recently it has started overflowing not stopping when it's filling. This does not happen everytime and it does not leak any other times but when it does what a...
Usually this is caused by the water inlet valve sticking in the open position. If you can catch the washer while it's overflowing, unplug the washer. If the water stops, then the problem is most likely a pressure switch or pressure hose. If the water does not stop, it is most likely the water inlet valve.
May 25, 2010 | Maytag Washing Machines
When machine is filling with water, it overflows
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Apr 27, 2010 | Maytag Neptune MAH6500A Front Load Washer
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Aug 02, 2008 | Maytag Washing Machines
Washer does not stop filling and it overflows!
check the pressure switch tube connectiong to the tub for a hole or crack first
Apr 23, 2008 | Maytag Performa LAT2500A
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
