Question about Precor EFX 546i Elliptical Version 4
My elliptical was making sounds and vibrating when the ramp was going up and down the last week or two. This morning, the ramp stopped going up and down completely. The display is still the same, I can still adjust the resistance, and when I try to adjust the incline, I can hear the motor, but nothing happens. Any ideas?
  • terrahjan Apr 26, 2010
    I was wondering if it could be a belt problem, since I think the motor is still working fine. Is there more than one belt on the machine? Are they easy to replace? Do you know how much a serviceman might charge?
  • 3,866 Answers
I feel the motor is fine at this point and a belt would be culprit to this issue and there should be two belts on this model if i am not mistaken. If you take it into a tech they charge around $45 per hour respectively the part might be a bushing or a loose or slipped belt in this case.
I hope this information does help and the accept button for my efforts.
Posted on Apr 27, 2010
    President:
  • 1,469 Answers
Since you have been using it for a while and has not developed any problem lately, you can use this troubleshooting tips to check exactly what the problem is, by checking what might be the actual cause of it.
The main concentration is n the engine part which might be jammed maybe by any substance or particles that got into it some how.
You can Open the engine area and check, for anything holding it not to ramp.
First, Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
Do not be concerned if you see small particles left on the guide rails. Over time, the roller wheels gradually wear down. When this occurs, they leave residue on the rails. Because this is considered to be normal wear, all you need to do to fix the problem is wipe the rails off with a damp cloth.
Minimize the risk of receiving erratic readouts on the monitors by avoiding outside interference. For example, gripping the heart rate handlebars too tightly can affect the monitor. Similarly, the heart rate grips can be rendered less effective when there is too much vibration. Consider not holding these monitors throughout the workout to minimize vibration. The readouts also can be affected by jewelry. To minimize errors, take off rings and other jewelry before working out on an elliptical machine.
Note:
Dry or cold hands can alter how an elliptical machine measures your heart rate. Rub your hands together or use moisturizer to reduce the possibility of your hands affecting the readout.
Good luck.
Posted on Apr 26, 2010
  • Egwe Emmanuel Onyedikachi
    You can also service the engine and i would advice before you tamper with it, if it has any guarantee on it, before anything, make sure you contact them first so that they can give you a replacement.
Elliptical makes grinding noise every time right foot goes down
It can be a couple of things 1) the stair arm wheel has bad bearings. You can switch the right and left wheels to see if the problem follows the wheels. 2) make sure the ramp the wheels ride on is clean and it helps to use a clear silicone gel applied lightly on the ramps. 3) if the noise is from inside the front it is likely bearing related but can also be a belt with wear. What type of nose? Is it cyclic? Does speed and resistance change the sound? Does it get louder of quieter as the workout progresses?
Sep 06, 2014 | Proform 585 CSE Elliptical Trainer...
Squeaking
I imagine if 106 people have responded then at least one may have asked if the squeak is coming from the wheels. I see it every week under warranty. the ramps and wheels need time to wear a little and until then they can be hideous. its counter intuitive being as that the ramps and wheels are supposed to be cleaned all the time. BUT, when new they make a racket and the easiest way to shut them up is a to rub a bar of soap on the ramp where the wheels travel. it shuts them up and holds a little dust over time to wear the shine off the wheels and make them act as they should. Beyond that I would need to know where the sound was coming from if not there.
Mar 24, 2014 | Precor Efx-5.33 Elliptical Machine...
On an incline higher than 5, there is a metal on metal sound as I press down my left foot. I removed the front panel but I can't tell if it's the lift mechanism or the ramp....
Is the ramp steel or aluminum? (steel is magnetic, aluminum is not) If steel, the ramp probably broke - if you tip it over, you may be able to see the tear in the metal. Replace the ramp.
Mar 14, 2014 | Precor EFX 5.17i Elliptical Fitness...
Nordictrack cx1055 vibration problems
see the next steps: Lube and use the logically. God bless you
Inspect the leveling feet on the rear stabilizer of the elliptical. Note if both sides are not flush to the floor. Unplug the machine if they are not flush to the floor.
  • Turn the leveling feet on one side or both with your hand until they are fully in contact with the floor so the machine will not make noise and tilt sideways during workouts
  • Plug in the machine. Use the machine as normal and listen for any noises. Clean and calibrate the ramp again if there is noise but the machine doesn't rock, and adjust the leveling feet again if the elliptical wavers.
  • Aug 05, 2012 | Exercise & Fitness
    Norditrack cx 1055 & vibration
    see the next step and LUBE very well, and tight any Bolts. USE the common sense. Read you instr. manual or download from www.iconservice.com
  • Turn the leveling feet on one side or both with your hand until they are fully in contact with the floor so the machine will not make noise and tilt sideways during workouts.
  • God bless you
    Drum is making a loud banging noise during spin, it is brand new
    Some banging or knocking during the ramp up to spin speed in this washer is normal. It is difficult to determine whether your washer has a problem or not based on your description. This banging lasts for varying amounts of time until the load is balanced and the washer ramps up to the full spin speed. If the load can not be balanced on the first attempt, the washer will ramp down and then tumble and attempt again to ramp up to speed. This may be the same thing that you are hearing when your washer ramps up to spin speed. Since the washer does spin at the full speed, there is not likely a problem with the washer. The components are designed to withstand repeated vibration and reasonable banging or knocking. The washer will vibrate to some extent at high speed. If you feel that the vibration is excessive, I recommend that you check the stability of the leveling feet. Press down on the diagonally opposing corners of the washer to check for play. If the washer rocks at all when conducting this test, I recommend that you adjust the leveling feet to eliminate this play even is the washer is not perfectly level after making this adjustment. This may help reduce the banging and vibration. Other than that if it is brand new call the people who you purchased it from so you don't void any warranties by taking it apart.
    Sep 08, 2011 | Washing Machines
    I have an efx 546i and when I try to use the incline the panel states: No ramp, low battery
    The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
    Jan 03, 2010 | Precor EFX 546i Elliptical Version 4
    The ramp will not go up or down. It's states low battery (546i precor)
    Dec 29, 2009 | Precor EFX 546i Elliptical Version 4
    Precor EFX 546i Elliptical Version 4 Logo
    242 people viewed this question
    Top Precor Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Shehu Pro
    Shehu Pro
    Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
