Question about Dishwashers
I need to know how to fix my dishwasher. It's a portable Maytag. older. Not sure how old. It will fill up with water and heat it up, but it gets stuck there and will not wash the dishes.
  • arrowwoodfam Apr 26, 2010
    Thank you. Much appreciated.
    Where is the thermostat located (approx) and what does it look like?
  • 19,396 Answers
Hi.
If the machine fills and heats up the water, but does not proceed any further in cycling , that means that the timer board did not detect that the correct temperature has been reached.
The machine keeps heating or filling warm water, and the cycle does not advance.
When this happens it usually means that the thermostat is faulty.
The thermostat can be tested by a technician reading Ohms at its contacts and jumping or opening its contacts.
The thermostat must read zero or very low impedance at room, and it will cut off reading no continuity when the limit temperature is reached.
If the machine keeps cycling , then the thermostat is not opening, or it is not reading temperature because defective.
To find parts you can use the links listed here: Parts and diagrams.
If you need to call a technician, use the phone number listed on the owners manual or see Fixya directory.
Regards.
Posted on Apr 26, 2010
  • Ginko
    Ginko Apr 26, 2010
    The thermostat has two contacts and a bulged coin looking part, approx it looks like this:
    It is located near to the heating group, or on the warm inlet, depending if the model is self heating or not.
Hose/ Adapters for older Maytag Portable Dishwasher
The sink faucet may have to be modified by installing an adapter.
Jun 22, 2017 | Maytag Dishwashers
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Portable maytag dishwater leak...older model
this link should help you out.check for the column "dishwasher water leak".
click here
will wait for your comments.please do rate my solution if liked.thank you.
Jan 04, 2009 | Dishwashers
Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Jan 01, 2009 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag portable dishwasher is not draining
try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
Dec 05, 2008 | Maytag MDB9600A Jetclean II Built-in...
Maytag Dishwasher
Newer Maytags should fill close or up to the heater not over. Sounds like your alright for now but I would get that water line fixed.
May 15, 2008 | Maytag 24 in. MDB8951AWS Stainless Steel...
MDB7600AW water level
I'm not sure if it is suppose to fill above the heating element. The heating element may just be there to dry the dishes instead of heating the water. Try using a pitcher to fill the unit manually to above the heating element. If water drips out from below the kick plate then you know the water is not suppose to go that high.
Let’s say the unit is indeed under filling.
Check for a deformed shaft on the water level float. Remove the kick plate and look for where the shaft of the float touches a micro switch. Often the shaft is bent sideways and only engaging the micro switch indirectly. Straighten by hand for a temporary fix or reinforce the shaft with aluminum tape and sewing needle. Keep the retrofit light weight to avoid problems with water overflow.
Mar 11, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwasher fills up with water and then does not run
fixya not being an actual repair shop has no idea what might be wrong since we can not test the unit , nor do we know what a local shop might charge for it
Oct 09, 2017 | Maytag 24 in. MDBH950AW Built-in...
Older portable dishwasher
nothing it needs a switching kit or drain solenoid kit rather
Dec 30, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
