Question about Bosch SHU9915UC Dishwasher
The motor is running but no water going in the dishwasher
  • Bosch Master
  • 43,501 Answers
Here is a tip that will give you some things to check out to solve your problem...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Apr 27, 2010
My dishwasher sounds as if the motor is running but there is no water spraying.
Most likely cause is the spray arms are blocked. You need to ensure it is the wash pump motor that is running and not the drain motor. Do you see water sitting at the base of the dishwasher? Does the machine complete a wash cycle (even if the water does not appear to circulate)?
Jan 07, 2011 | Hoover 24 in. HD96M ALU Free-standing...
Motor starts but water doesn't flow into dishwasher.
Start your dishwasher like you would normally. You should here water going into it first. After that you should here the motor running. When you here the motor running, turn off the dishwasher and check to see if water is in the bottom of the dishwasher. If there is no water in there, most likely you have a bad water valve or the controller is not sending a signal to the valve to open.
Please vote
Nov 23, 2010 | Asko D1716 Built-in Dishwasher
Dishwasher makes a lot of mechanical noise when running
If your dishwasher seems noisy, check these:
Water-inlet valve
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor
If it's the motor that's noisy, either of these may be the "culprit:"
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump
Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
1 Look at the heater fan to check for rusty or squeaky parts. If defective parts are found, replace the fan. If not, go on to the next step.
2 Replace the water inlet valve, which is located at the bottom of one of the sides of the dishwasher, beneath the lower access panel. As a water inlet valve ages, it can sometimes slowly stop working correctly, switching between "on" and "off" every few seconds. This can cause a shaking and rattling noise. If this does not fix the noise, go on to the next step.
3 Remove the lower rack and the lower spray arm from the dishwasher, removing any screws as needed to do so.
4 Beneath the lower spray arm is a pump that contains a propeller. Check the pump for debris (like small bones, seeds, or fragments of glass) that might be causing the noise. If this does not fix the noise, go on to the next step.
5 Beneath the pump is the dishwasher's motor. Check to see if the plastic dish at the top of the motor has broken off. If it has, it may be rattling when the motor is on and causing the noise. In this case, replace the entire motor.
6 Check the bearings on the motor. If they are worn out, replace them.
7 If you cannot trace the noise to its source, try replacing the motor.
Sep 03, 2010 | LG Dishwashers
Upperrack water pressure
1)check the wash motor is freely rotating. 2)any jam in the wash motor.
Jun 03, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher began leaking underneath when turned on. Humming as if trying to start, but nothing further exept water on floor
I don't know how old this dishwasher is but the symptom your describing sounds like the ceramic water seal on the bottom of the impeller assy but above the motor has failed. When the seal fails it allows water to run though the motor and then the bearings in the motor fail. Once water starts running though a dishwasher motor they are pretty much shot. The reason for this is that the leak starts out slow and it leaks for a long period before you ever see the water under the dishwasher. So by the time you see the leak water has been going through the pump / motor assy for weeks or months. By that time the service technicians only option is to replace the motor pump assy.
Kelly
Apr 14, 2010 | Bosch SHU5315UC Dishwasher
Dishwashing detergent isn't dissolving
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Jan 18, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher has water going in to it and it drains but it's not making it to the arms, my dishes are still bone dry after all cycles even pre rinse.
it appears ur wash motor is not running.try this-start the unit and let it run for 2 min( this is the water fill period) and after 2 mins u should hear motor running and water splashing sound.u can even open the door and look for water falling from the spray arms.but after 2 mins if u hear only a humming sound and no water splash sound then motor is bad and needs to be chgd.drain motor is seperate for draining the water.
Aug 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Have model PLDB999AC0 water is not coming on
Is the supply turned on and power applied to the dishwasher? Make sure you've turned the angle stop to open the lines and supply the dishwasher with water. If this is a new problem and it had previously been working alright, then you're looking into a problem with the timer or motor. The motor contains a solenoid that activates a gate to allow water to flow into the dishwasher basin. Remove the kick plate and watch the motor as you allow the dishwasher to run it's cycle. You'll see it go up and down and probably hear a loud hollow sonnd when it activates. Also, make sure the motor is running, and if it's bound, try using a screwdriver to jump start the motor. If it starts up, this sometimes fixes the problem, but it may just put off the inevitable replacement.
Jul 08, 2009 | Frigidaire Dishwashers
Detergent packs are not dissolving
Either:
Good luck,
Vlad
Apr 21, 2009 | KitchenAid 24 in. KUDS02SRSS Stainless...
Dishwasher pump will drain but not force water into spray arms
Hi there is a scond motor that forces the water through the spray arms it sounds like the motor has seized .
Dec 11, 2007 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Bosch SHU9915UC Dishwasher Logo
193 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
