Question about Dishwashers
Water is not going out after wash. Have taken screen out and clean but still not going out
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 27, 2010
Can screens be taken out of a Whirlpool top loading HE washer....or could it be another reason?
Screen are to protect the valve from dirt and sand, you can clean the screens at the inlet to the washer but not advisable to remove them. If this is an ongoing issue you can call you dealer and ask for another set of screens to clean out at the hose connection to the wall, it could be easier to clean in the future. You can also call you local plumber for advise on how to prevent this from happening. Good Luck
Apr 17, 2016 | Whirlpool Washing Machines
Canon powershot sx100is. Error 24 on starting and camera turns off. Can view pictures already taken.
some dry wash lens,display & camera.mother board clean with isopropyl or" petrol.if use ******** wash very good.something heat with mobilephone past.so work it again.harry up in one day or"So4 damage your board.
May 30, 2012 | Canon PowerShot 600 Digital Camera
LG washing machine. Fabric softener not being taken by dispenser drawer. It has been washed and the drain pump and filter also cleaned out. Problem remains so why is the conditioner not being taken?
Please remove power of the unit and this will reset the unit. Now select a program that is different from the earlier one and see if this works. Also check once again on the filter and check the dispenser drawer to be in place. Set the water level once again.Hope this helps.
Mar 12, 2012 | Washing Machines
It shows an F 20 fault after it goes to the wash cycle. I have taken the hoses offf and cleaned the screens. It is getting plenty of water throught the fill valve but still stops with an F 20 fault.
Hi
Thanks for using FixYa. Error F20 indicates no water is entering in machine and/or the pressure switch trip was not detected. To resolve this issue check the water supply has been turned on, then check the water inlet valve for any clogs and clean it. If there is water in the unit then check the drain pump and also verify that the pressure switch is working fine. If the water inlet valve has gone bad then it should be replaced. Also check the wire harness connections to the water inlet valve and pressure switch. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When washing machine goes to rinse cycle, water barely comes in
I am going to guess you run a warm wash, and cold rinse. This sounds like the screen on the cold water inlet is clogged. Shut the water off and remove the hose at the back of the machine. Look in the water inlet and see if the screen is clogged. If so, carefully scrape it as clean as you can. Use a straw and blow into it to help clear it out. Replace the hose and try it. It does not need to be perfectly clean, but at least half way opened will suffice.
Jan 01, 2010 | Kenmore Washing Machines
Cold water flows slowly into the tub when doing wash. checked the screen at the water inlet on the machine and it is clean. water flow on the connecting hose is also ok
If screen and water pressure are ok then the cold water solenoid valve assembly could be partically clogged. The older ones could be taken apart and cleaned. I cannot say if yours can be cleaned.
Jul 07, 2009 | Speed Queen Washing Machines
The washer is very slow to fill up with water.
cut the water off to the fill hoses,,than remove fill hose and clean water inlet vavle screens with tooth brush..onthejob
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Can only get hot water in my maytag stacker...no cold...checked water supply and hoses...they are all working fine. Is it the unit the hoses hook up to that needs replacing?
First, take cold water supply hose off and make sure there are no blocked screened washers in either end. Now for the most likely cause, check the screen in the inside of the cold water inlet, right where the hose screws onto the machine. The screen can generally be taken out and cleaned. If it is clear, that just about only leaves a bad water inlet valve. (yes, the part the hoses screw onto)
Nov 09, 2008 | Maytag Washing Machines
Cold water only trickling into my washing machine
unfortunately it sounds like you have a stuck plunger in the cold side of your water inlet valve.if the screens are clear and your water pressure is good,thats what you have.
Sep 25, 2008 | Washing Machines
Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Jun 22, 2007 | Creda W100FW Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
