Question about Canon FaxPhone L75 Plain Paper Laser
I am getting a white line down the entire page
  • 385 Answers
Is it when u send or recieve faxes!If on sending(open the part where u put in the faxes to sent!U will see a big black roller and under that a small black one,undeer that a long strip of glass,make sure that there's no marks of any kind on the glass!If recieving it might be on the fax that is sending the fax!Good Luck!
Posted on Apr 26, 2010
When scanning, why does the entire left side of page have a line down it one inch in from txt?
If you are scanning from the ADF - open the scanner cover and clean the narrow glass plate at the left end. It is usually caused by a speck of dirt or white out on the glass.
If you are scanning from the platen (large plate) you may have a faulty point on the scanner bar or a dead light diode. Alternatively you may have the source document in the wrong place and you are getting a page edge mark.
Apr 14, 2016 | Brother MFC-8370DN Laser Multifunction...
I get a thick vertical black line/margin down the entire page when i scan on my SX115
Please make sure the scanner flatbed is clean.
You can also try to copy and see if it happens on copying.
If it does, then your printer needs servicing.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
When I photocopy I get a black line down the page, I am using a C
check the drum unit maybe the drum or the cleaning blade is the problem
Jan 04, 2010 | Canon PC-950 Black and White Copier
I am getting a white line on my pages that go from the top of the page to the bottom. What could cause this?
A line all the way down the page means you have something blocking the imaging module like a bit of dirt or a piece of torn paper. Look in the area where the white line is, or it also could be toner being scraped off the page near the fuser, in that case you may see a smudge next to the line.
Dec 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
A white line on entire page
If you have the machine for three years then I would say the the print head is coming to the end of its life, there are two solutions,
1. Follow the instructions below and activate the jet substitution mode.
2. Get someone to remove the print head and clear the blocked jet manually.
Note: The print heads on these machines are very expensive so if you have to replace it, just buy a new machine as it will be cheaper then replacing this part!
Jet Substitution Mode bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Turn Jet Substitution Mode Off], and then press the [OK] button.
    NOTE: If the 'Turn Jet Substitution Mode Off' option is not displayed, the Jet Substitution mode is not enabled.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the main menu.
Mar 30, 2009 | Xerox Phaser 8500/DN Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Dark Bar only on Sent Faxes
open the top where you insert the paper to fax look at the strip of thin glass is there any white out or toner on it that is most likely your line, clean
Nov 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Canon FaxPhone L75 Plain Paper Laser Logo
103 people viewed this question
old marine
old marine
