Question about D-Link AirPlus DI-614+ Wireless Router
D-LINK DI-614+ MODEM HAS BEEN CHECKED AND WORKING, BUT WHEN D-LINK IS CONNECTED CAN'T CONNECT TO INTERNET. JUST HAPPENED LAST 24 HRS.
  • 550 Answers
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on Apr 27, 2010
D-link DI 524 Router (Quick Router Setup - error: 103
103 most popular error on DLink Modems and Routers.Error occurs when your computer or router is not able to find the internet connection. Reason behind settings of the modem or router.
Try to use :
  • "https" instead of "http" in the URLs.
  • Check Firewall is not blocking your internet connections.
  • Reset your modem or router.
For setting up and configure your router http://support.dlink.com/index.asp and D-Link Router Support for technical help.
Jan 27, 2014 | D-Link Computers & Internet
My internet connection light on my modem won't light up
try to login into the router interface and check the settings and make sure it is connected
Jul 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Connectivity to email and internet increasingly fails.
next time it happens leave laptop on and plugged into router and unplug router only. If laptop now works problem is in the router you will probably have to reset router to default and use the router wizard to re-program!
Apr 07, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Modem and wireless not talking
If u r inside a wireless network and internet is ok, u will able to ping both the wireless router gateway and modem gateway. If u cant ping the modem gateway, u can try connect the modem directly to your pc, and test again. U need to make sure the modem is OK, and able to connect to internet. Then only u move to check router. This is due to very often internet access having problem.
Mar 10, 2009 | D-Link DI 514 Wireless Router (DI-514)
No internet through router
** Try this steps
- Check physical connection (Modem=WAN Port, Computer=Port1) *should be hard wired connected*
- Power cycle modem and router for 2 minutes (to turn off the modem and router)
- Check web browser for Internet connectivity
* If nothing happen reset the router for 15 seconds and try the steps again.
Feb 14, 2009 | D-Link AirPlus DI-524 Wireless Router
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
D-link router DI-604 was working (networking all 3 of my computers) fine with comcast internet until last week when we upgraded to their "Triple Play package" and they put in a new modem. Now I...
Since you have a new modem the DI-604 needs to be reconfigure to work with the new modem , if you have the setup CD for the router yuo can just simply run it so it will configure the router to work with the new modem but if not you can manually configure the router by accessing its setup page where youc an do some changes on the router settings including the internet connection settings if you're not familiar on how to do that it will be better if you can contact a tech support group that can walk you through with the process, you can contact this number for help 1-877-787-8749 they are open 24/7....
Oct 21, 2008 | Computers & Internet
NOT WORKING AFTER POWER OUTAGE.
are u getting all the lights on the router?if yes then connect the router with modem n if its wireless then turn off all three devices
then turn modem on first n wait till the lights on the modem get settelled,then turn the router back on n the computer,n check whether the computer is picking the wireless or not,if yes try the
internet.
Apr 20, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
WAN
WAN s not for your use now. dont dig with it bro..
tel me one thing.. what kind of connection you have? does the modem stores the password or you type the pass each time manually to connect to internet
Dec 25, 2007 | D-Link DI-704P Router
D-Link AirPlus DI-614+ Wireless Router Logo
154 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
