Paper jammed - removed - replaced removable piece no response (light) when activating on switch
  • 19,396 Answers
Hi.
If there is no power at all (no light), and no sign of life, then the problem is the power supply.
Check the power cord, ensure that it is weel plugged to the power adapter AC socket, and that the DC socket is well plugged into the printer. If the AC socket hhoks up directly into the printer, ensure that the cord is well pushed inside the printer socket.
Some printer like most Lexmark inkjets use a power module that looks like a black plastic block that can be pulled away from the printer. Ensure that this is in correct position. Disconnect main power first.
If there is no evident problem with power cord and adapter (when present), then the fault is the printer internal power supply. This can get easily damaged by a short caused when pulling printer cord or moving the printer.
In that case call the manufacturer at the number listed on the owners manual (or on their website) to repair the fault.
Regards.
Posted on Apr 26, 2010
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
Sep 04, 2014 | Lexmark E Office Equipment & Supplies
202 paperjam open rear door. My printer did have a paper jam and we removed all the paper we could find, but that message won't go away and it hasn't worked since! HELP!
Hello and Welcome to FixYa
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Advanced
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path. Some of the switches or sensors might have gotten stuck.
Jan 04, 2010 | Lexmark T630 Laser Printer
It always says paper jam and it has no paper jam
alternative :
if the problem remains, some of the sensor / switches might have become stuck or are out of place, or there is still a small piece of paper or something else inside the machine and its coming up as a paper jam.
The machine would need to be taken apart and cleaned to solve the issue.
Nov 03, 2009 | Dell Photo 964 All-In-One InkJet Printer
I have a paper jam 071-100 and cannot find it. I have no manual and I need help.
alternative :
if the problem remains you will most likely have to take the machine apart to find the paper or unjam one or two of the paper path sensor switches that may have become stuck.
Sep 12, 2009 | Office Equipment & Supplies
Printer will not work after paper jam fixed
alternative :
Jul 09, 2009 | Canon iP4500 Photo Printer
Cannot clear paper jam on L7580.
give this a try
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Apr 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Jamming problem
try this
alternative :
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Paper jammed. Remove jammed paper and press the printer's RESUME button.
give this a try
alternative :
Dec 15, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Error LED blinking after paper jam, won't print
I have a similar but different model B4300. Several others, & I have found that a small piece of paper 1/2 square may lodge under a plastic guide, holding open a switch. This is very difficult to notice if you don't know where to look.
Open top lid
Remove the ink cartridge/roller drum as a single unit.
Look in the printer at the metal roller in front.
A Plastic strip on top & in front of the roller covers 2 square holes which should look dark. On your LEFT, as you face the unit, there is a small magnetic switch, to the LEFT of the LEFT square hole, under the plastic.
In my case, the paper was seen as white in the hole, and extended under the switch. I was able to grasp it with a small medical forceps, next to the switch. By gently twisting, I pulled it out without taking the unit apart.
The printer then worked perfectly after the paper under the switch was removed.
Dec 13, 2007 | OKI B4100 Laser Printer
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
