Question about Zebra 105Se Thermal Printer
I would like to have a directional arrow print on the label at the end of the text
    Scholar:
  • 97 Answers
This is usually done by adding a graphic file (.jpg or .pcx) of an arrow to your label design software.
Posted on Apr 26, 2010
Change the font style on a Bee3 label maker
1. Press "Style." The screen shows "lines." Press "Return." 2. Use arrow key to select "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select "1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screen says "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREA Label." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312 fmi or a manual! Changing the font on your Sun BEE3 BEE3 label printers
Apr 10, 2014 | K-Sun Corporation BEE3FB - BEE3 LABELShop...
Printing text at the same label in two directions
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Instructions for brother p touch 1000
Instructions1 Turn on the device by pressing the power button. If this is the first time that the machine is being turned on, select a language with the arrow buttons and press the return button. Select a unit with the arrow buttons and press return. Set the date and time with the keypad and the return button.
2 Type in the text for the label using the keypad. Correct mistakes by pressing the "Backspace" key and retyping. Press the return button when the text is ready.
3 Select the appropriate styles and features for the label. The device will provide you with a wide range of choices for the size, style and width of the text. Simply select which feature you would like with the arrow buttons and press the return key to move on to the next option.
4 Print the label by pushing the "Print" button. Make sure there is paper in the device. It may be necessary to press the "Feed" button to align the label within the device. Print as many labels as necessary. To erase the text, simply press the backspace button until the text is gone.
5
Turn off the device by pressing the power button.
Mercedes Custom Parts
Jun 06, 2012 | Brother Office Equipment & Supplies
I want to print a label with two lines of print on it. How do I do it?
To create a two-line label 1. Type the text for the first line and press INSERT. 2. Use the arrow keys to select Second Line and press . A multiline symbol is inserted at the end of the first line, but will not print on the label. 3. Type the text for the second line.
Here's the manual, see page 12 - http://www.dymo-label-printers.co.uk/downloads/LetraTAG-LT100H-Manual.pdf
Jul 14, 2011 | Dymo LetraTAG Thermal Label Printer
I have a Bee3 label maker and I need to know how to change the font size.
1. Press "Style." Thescreen shows "lines." Press"Return." 2. Use arrow key toselect "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select"1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screensays "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREALabel." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312for a reference manual. We can answer any other questions you might have too!
Jan 18, 2011 | Office Equipment & Supplies
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
How do I print vertically?
  1. Type the text for the label.
  2. Press the "Function" key.
  3. Press the "Left" or the "Right" arrow key until STYLE is displayed.
  4. Press the "Return" key, which is the key with the broken arrow pointing left.
  5. Press the "Left" or the "Right" arrow key until VERTICAL is displayed.
  6. Press the "Return" key.
  7. Press the "Print" key.
Jun 29, 2009 | Brother P-Touch 1180 Label Printer
Printronix T5000r Label Syntax to print " character
It is a syntax error.
It should read:
D;POINT;075;095;12;6;"text"
You might be able to get away with this:
D;POINT;075;095;12;6;"test";"text"
quotes have to be in sets of two and elements have to be seperated by semicolons.
Jul 14, 2008 | Printronix T5000r Label Printer
Canon PIXMAiP4500 printer
Select the print dvd/cd cover application, when it opens it shows the outline of the label
Select 'text' and type your text, then adapt it by font, style, size and positioning.
Can preview on the label and drag it around like a text box in MS Word
For images, select 'insert' from the menu on the screen, browse to your phots and select one, then accept it and preview/resize on the label shown on the screen
Then select 'print'
Get your cd hol;der ready, open the front of the printer, then open the flap with 'Canon' on it
Wait foir screen prompt to insert the holder, with the cd upwards facing and at the end nearest the printer
When prompted, insert it so the 'arrows' on the left and right are flush with the front edge of the flap you just folded down
Jun 01, 2008 | Canon iP4500 Photo Printer
RE: Dymo Letra Tag
If you use the "dynmo letratag 2000", just press the shift button (the green arrow button) and then the letter "N" (above that letter you should see the text "2=").
That will add a carriage return on your current position and the following text will appear on the second line when printed.
Nov 14, 2007 | Dymo LetraTAG Thermal Label Printer
Zebra 105Se Thermal Printer Logo
73 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
