Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Mower smoking and running rough
My John Deere riding mower ran out of gas so after I filled up and started it, white smoke came billowing out from under the hood. It was also running rough.
  • 54 Answers
Check the gas you put in, it sounds like it had water in it.
Posted on Apr 28, 2010
Wont run and emits white smoke
Hi Jeremy:
Sounds like there is still diesel in the fuel system.
There will be a plug on the bottom of the carb.
If you unscrew it and allow it to drain, it will flush the carb.
I'd suggest changing the fuel in the tank again.
You may also need to change the spark plug.
You won't have damaged the engine.
Cheers.
Jun 27, 2016 | John Deere Riding Lawn Mower. EZtrak Z425...
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
USE DIESEL IN GAS MOWER
Hi, drain the diesel from the fuel tank and carby bowl and re fill tank with correct fuel. It will smoke when first started but it will clear and run fine. Regards Phil.
Jul 16, 2012 | John Deere Garden
John Deere LA110 riding mower has gas in the oil
Try stripping it down and having alook sounds like the piston ring has snapped and is pumping gas into the oil that would explain why the oil is coming out the the exhaust the black smoke is just oil burning up ou also might want to clean the carb alittle too.
Mar 19, 2012 | John Deere 22HP Hydrostatic 42" Riding...
Hello my name is John. I have a 345 John Deere lawn tractor. The problem is that it starts idles rough won't idle up and does not run strong enough to move the mower. It just chugs and puffs white smoke...
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Jun 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My john deere 737 lawn mower runs ok untill I leave the seat to pick up limbs. When I return it will start running rough and smoking. It seems to be an intermittent problem. It also uses alot of gas. Any...
from what you have said sounds like you have a dirty carb.,try cleaning or rebuilting carb. change air filter,, hope this help you ,, good luck
Aug 15, 2009 | Garden
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,087 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
