Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Printing PDF to Bizhub c252 issue
I'm getting the message 'job has been done improperly. Check the log'
I've had the printer for over six months (on lease) and had no printing issues untill today. I quite often print up to A3 drawings in PDF.
Any ideas??
  • taminol
    taminol May 11, 2010
    Hi David, The problem you describe suggests an authentication problem. Do you use PIN numbers or any other means of authentication when sending a job to the printer?
    Sniper:
  • 62 Answers
I had this once. We simply deleted the Printer Driver and reinstalled it. Also, when reinstalling the Printer Driver we chose the PS (PostScript version).
Try that - hope it helps
Kind regards
m-press.biz
Posted on Jun 15, 2010
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
Bizhub c450 what is job has been done improperly check the log
Go to "job list" select job high lite then touch details what does it say????
Feb 03, 2014 | Konica Minolta bizhub C450 Scanner
Printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
May 27, 2010 | Konica Minolta bizhub C250 All-In-One...
Job has been done impropely. Check the log
you have to check the settings, check that everybody can read/write to the folder you share, be sure to give the right path to the directory forr printer. maybe you have to use name and pwd
Sep 25, 2009 | Konica Minolta bizhub C250 All-In-One...
Job has been done improperly check log files
The first thing to try is to restart the Bizhub. Power switch for that is located behind the front panel where the toner cartidges are. Not the switch to the side of the operation panel.
If that doesn't work, you need to check the job history. Press details, there will be a description of the error.
Server Connect Error: The Bizhub cannot find your computer.
Things to check:
Firewall, ports that need to be open are TCP 139, 445, UDP 137, 138
Netbois resolution not working, try using your PC's IP address instead.
If using Host Name to resolve, try Host name in uppercase.
Folder Not Found:
Check to make sure you are using the correct share name. Not necessarily would be sd.
Login error:
Need to use a Username/Password which is an active account which has priveledge for the shared directory. If on a domain, use a domain authentication string for the username (username@domain.com) If on a workgroup, \\COMPUTERNAME\Username If your password rotates every 60-90 days, could be that all you need to do is update the Bizhub with that information.
Jul 30, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Trying to use photo copierfrom the touch pad
eee, what version machine you have ?
C252 is copier
C252p is a printer version without copy function
what are you trying to to? copy ? scan ? print ? fax ?
Nov 29, 2007 | Konica Minolta bizhub C250 All-In-One...
Log File
what it says in job history ? job done or not what error ?
Nov 16, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
522 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
