Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
The temperature display is reading 0 degrees
The temperature display on the exterior of the door is reading 0 degrees Fareignheit and the compression won't come on.
    President:
  • 949 Answers
Zero degrees F is the normal operating temperature for a freezer. The compressor should not come on until the time is above that.
Posted on Apr 26, 2010
What does the temp display on the freezer tell me?
unless this is a dedicated freezer only and not a side by side or over/under , there's no way it's going to get down too 0 degrees inside a warm home , nope not gonna happen
also its not good for you to set this there as compressor wont cycle properly there and entire freezer will ice up , then believe it or not it will get warmer not colder wastes a lot of power as well
Sep 10, 2015 | Freezers
Our Freezer is not running correctly and is staying at a temperature of about 40 degrees. The temperature display reads REC. Please help. Thanks
REC means recovery. It is trying to make temp and is not. Could be frozen up evap, no fan running, door not closing, issues with the refrigeration system.
Jun 19, 2015 | Hoshizaki Commercial Freezer SafeTemp®...
The upright frigdiare freezer displays -10 degrees and runs continusly i couldnt set it to 0
Good Afternoon Friend,
I understand your Frigidaire freezer, model# LFFH21F7HWJ, is displaying -10 degrees and runs continuously. I also see that you were unable to set it to 0 degrees. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try the temperature to 0 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Freezer temperature came up to about 35 degrees. We took all food out. Temperature is holding around 32 to 35 degrees. This is on the colder setting that used to read around 0 degrees. What do I need to...
If there is frost on the back of the freezer then there is a defrost problem. If no Frost then i would advise you to take the back off the freezer and see if there is any frost on the coils. If no then the compressor is insuffecient and or no freon.
Mar 14, 2011 | Freezers
Just installed refrigerator. how long does it take to make ice the first time
The icemaker has a thermostat built-in that calls for water from the water valve at a certain temperature. Ideally, the freezer temperature should be around 0 to 10 degrees. Ice production, depending on temperature, should initiate around 6 to 8 hours later (assuming that the door remains closed most of the time).
Feb 19, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Temperature display reading 32 degrees on delfield 6000 xl freezer unit. Should be set for 0. door has been opened one time this morning. Where is display box to check troubleshooting codes located on...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 16, 2010 | Delfield Freezer Series 6000XL Remote Half...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
179 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
