Question about GPX ML648B MP3 Player
It won't start at all. I haven't used it for a long time and now it won't even start. I tried to reset it, but not even that will work. Is there another way to restart/reset it?
  • J J Rodriguez Apr 27, 2010
    Thanks a lot for your help!
    I just need to see how to change the battery now.
    That shouldn't be difficult.
    Thanks!
    President:
  • 1,469 Answers
Won't start, do you mean, not coming on or coming on an freezes?.
If it comes on and freezes, you will need to flash it. flashing is when the memory of the mp3 player malfunctions and has memory loss, it helps to restore the memory back and the mp3 will start working properly again.
When you flash it, it will work normal again.
If ti does not come on, you will need to check the battery to see if the cell of the battery is weak and will need to be replaced.
Which ever you try out, you will get a solution.
Make sure you charge the battery very well to be sure, or you can use another one to test.
Take care.
Posted on Apr 26, 2010
I haven't used my calculator in some time. Now when I go to use it, it won't turn on. I've pressed on and clear and reset. Nothing. It is solared powered and its not like I just change the...
If it is solar powered and hasn't been used in some time, the battery may have died, permanently. If there is no battery to replace then it is broken forever. Sorry.When batteries are left without juice for a long period of time they die, and cannot be recharged.
Sep 14, 2011 | Office Equipment & Supplies
My machine won't turn on when I flip the switch. It is properly connected, I tried it in several outlets - that are working for other appliances and I am left baffled. I haven't used it in about 6...
do you have user's manual with wiring diagram? if not try H.B. If you get one, there is a diode that keeps your machine from frying from over-voltage. Kinda like a fuse, but is not a fuse. If you can check voltage across it, it is not the diode. That is a simple start and the most common problem for not starting.
Aug 03, 2011 | Hamilton Beach 67601 Juicer
Hello Cindy Wells, I saw you on Fixya.com and I am having a bit of a problem with my Canon PIXMA MP490. Basically every time I try to print something the printer will start working (i can hear it...
hi there,
it may be that a paper sensor is picking up a small piece of paper in the printer. Has any paper ever torn in the printer? if so there may be some left behind. Carefully inspect the printer to see if there is any small pieces of paper in the printer. You could also try unplugging all cables and taking the outer cover off to inspect closer.
Re the ink cartridges, inkjet printers are notorious for ink drying out in the cartridges and the nozzles blocking with old ink, if the printer is not used at least once a week. It happened to me, i had to get a new printer.
Hope this helps
Tom
Jul 22, 2011 | Office Equipment & Supplies
My qlink Siena 150 got excessive oil build up in the air box from not draining. Oil got in carberator now won't start. I have cleaned every thing out completely and it still won't start even...
Drain the carb if you haven't already, be sure the gas valve is on and the plug wire is attached, check for a kill switch in the wrong position, then give the air intake a shot of spray starter fluid. Hopefully that will get you going again.
Jun 08, 2011 | 2008 Qlink Siena 150
Forgot the parental code how do we reset
Hello
Just unlock its Parential contol and reset the TV. NB: You must have its original remote control handset to proceed. If you haven't it with you, just boroww it from somone you know, who have the same model number of Tv; just to unlock it. After unlock, you can use universal remote or so.Proceedings are:
Most GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Jun 02, 2011 | GE GTD120 System
I have a 2001 s600 Benz with 90,000 miles, i haven't drove my car for 3 months. I try to start the car but the battery was dead. I got a hot shot, now when I try putting it in drive ir reverse, the car...
That is quite a car! Remove the negative terminal from the battery and allow to sit for about a minute. Is the battery in good condition even after sitting? You may "consider" replacing if there is even a glitch. This should reset the system. Let me know what you see.
May 19, 2011 | 2001 Mercedes-Benz S-Class
GPX ML648B  MP3 Player Logo
103 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
