Question about Canon PIXMA MP600 all-In-One InkJet Printer
MP610 won't print "Inner cover open" appeared after daughter attempted to change ink cartridge. Ink carriage doesn't come over into position for me to inspect the cartridges.
    Scholar:
  • 67 Answers
Turn off and unplug from the wall for 60 seconds. Make a visual inspection to see if anything is blocking carriage movement. Plug back into wall and switch printer back on. Give it a few moments to reset itself. If successful, you should be able to change cartridges normally. If not, you may have caused gears to jump out of timing. Try this process at least 3 times before you give up.
Posted on Apr 26, 2010
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Will not print. power light flashes green and orange. opening cover does not allow carriage to go to the cartridge change position.after many attempts to print, there is ink leaking from below the...
It goes to damage Ink absorber .Many ink absorb this pad.You must be reset it self or any workshop.if itself
1.Press power button and resume button realize resume button and press 3 time then go to power button.
Feb 12, 2010 | Canon i350 InkJet Printer
Pixma MP610 will not start up. Was working OK. Just under 1 year old. Printer detected by computer, and print carriage lifts, but will not move. Ink in all the cartridges Front lights blinking alternately...
6A00 indicates a problem with the carriage lifting mechanism. Simply put there is beam kind of thing that the cartridge carriage assembly on which the print head rides on and something on it is obstructing the carriage assembly. The fix? Open the printhead cover and turn on the printer. You will see that the carriage arm is extended and tries to move back to the initial printing position but it can't. Just give it a little helping hand and bingo! The print head moves to the correct position. You will then have to clean up whatever is blocking its path. Usual culprits being ink, paperclips, tiny bits of popcorn(or anything else you prefer eating while printing!:)
Let me know if you need more help,
Sai.
Jan 03, 2010 | Canon Office Equipment & Supplies
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
Inner cover of printer MP610 -error 'inner cover not closed'
I am still on . Get back if your problem is not solved.
Aug 03, 2009 | Canon PIXMA MP610 InkJet Printer
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Inner cover is open - what inner cover is that referring to
The inner cover is inside and just above where the paper comes out after you make a print or copy.  Reach in and flip the grey bar up to close.
Jul 10, 2008 | Canon MP610 Photo All-In-One Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
107 people viewed this question
old marine
old marine
