Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
Welder shutts off after turning it on - Lincoln Electric K1297 AC/DC 225/125 Stick Welder
    Problem Solver:
  • 14 Answers
You might be tripping the breaker...
Posted on Apr 26, 2010
99 expedition my fuel pump isnt working checked fuses is there a fusuble fink with key on the fuel shutt off switch behind right kick panel has no power to any of the wires?
Power comes from a fuseable link to the pump relay, then to the inertia switch on the dark green and yellow wire. Power from the inertia switch to the pump is on the pink blue or pink black wire.
Jan 20, 2014 | 1999 Ford Expedition
99 exedition wont start fuel pump not working check fuses and fuel shutt off switch when i turn key on tere is no power to the wires going to the shutt off switch
The fuel shut-off (inertia) switch is after the pump relay. Is the pump relay getting power and a ground signal from the computer ?
Jan 20, 2014 | Ford Expedition Cars & Trucks
Mig welder model# 205680 make a rare noise when turn on
Take the wire out of the hose to the gun and see if noise stops. You may have a short in the Trigger
Nov 16, 2013 | Craftsman 304 FI 95 Amp 120V Flux Core...
Television shuttf off
Do u have a sleep timer set up?
May 15, 2012 | Sony KP-51HW40 51" Rear Projection...
My lincon welder sa 250 won;t turn on after i turn it off
Lincoln's welders have a very weak on/off switch sometimes you need to wiggle the switch a little bit to help make contact. Try this, open the welders cover and using an insulated tool and insulated gloves try to bridge the switch. If the machine makes contact then buy a new on/off switch and change it.Other tip is to check your cable plug to see if all cables are still in place.
Nov 10, 2011 | Welding Tools
My snap on welder isn't working properly. With the heat dial turned all the way up, I have to turn the wire speed almost all the way down. Even with it in the hottest setting it welds cold. Won't even burn...
I own and love my Snap-On YA-212A and had a similar problem that turned out to be a power issue, not a welder issue. Repair costs and parts availability of these welders can vary wildly, it may be cheaper to replace it with a Lincoln, Miller, or Hobart. Snap-On uses more than one supplier to make their welders, if you tell me the exact model number I can probably tell you who manufactured it,
For now, try the following:
  1. Unplug the welder from the power outlet on the wall
  2. The power cable where it connects to the welder should be a twist lock type, make sure it is not loose. Take it off and look for any signs of arcing that look like it may have been a bad connection
  3. Look at the power connector that plugs into the wall and look for signs of arcing. If possible, take the back off the plug that goes into the wall and ensure that everything looks tight.
  4. Put the power cable back on the welder
  5. If your breaker box has a load controller turn it off and try your welder again
  6. Replace the circuit breaker in the breaker box on your house
Feb 26, 2011 | Snap-On Welding Tools
Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Apr 09, 2009 | Clarke Power Products Welding Tools
I have replaced the lamp.Now the lamp wont come on and tv shutts
Did you replace the lamp cover after replacing the lamp? Make sure the cover is properly installed.
Jan 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Frozen and won't shutt off
Unfold a paper clip and use the end to press the reset button on the back--it's the tiny black "hole" at the middle of the bottom next to the "passed" seal.
Dec 31, 2008 | Coby MP-705 Digital Media Player
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
270 people viewed this question
Top Lincoln Welding Tools Experts
joe2639
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
