Question about Honeywell Programmable Thermostat Heater
Blank thermostat, a/c won't work after changing thermostat
    Guru:
  • 415 Answers
Ensure you have a fresh battery. Also check for 24 volts A/C between R & C. If 24 volts does not exist, check for a blown low voltage fuse at your air handling unit.
Posted on Apr 27, 2010
1f88-290 thermostat is blank
Change batteries, the display should come up. If not, the thermostat is probably defective. Some of the cheaper White Rodgers stats require batteries to function.
Feb 20, 2015 | Heating & Cooling
Thermostat is working, but display is blank
My thermostat used to go blank when heating. It was caused by the overheat protector inside the heater. That switch cuts the power to the heater and the thermostat. The heater could also be burned out. If it's a 24Volt system, the power supply could be bad.
Oct 13, 2014 | Heating & Cooling
520 protech thermostat
What wires land where on
Jan 28, 2018 | Heating & Cooling
Thermostat won't change from heat to cool.
Go into the programing and change the reversing valve setting to the next number.
Jun 15, 2013 | Heating & Cooling
The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
May 10, 2010 | Honeywell Programmable Thermostat Heater
Chronotherm III Thermostat Completely Blank Screen, No Heat
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
192 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
