Question about Hunter 22451 The Brookline Brushed Nickel Ceiling Fan
Oiling fan Where do you oil fan. Does it have to come down?
Oil filter
,your oil filter is in the front of the engine, if you look down where fan is ,first your radiator then the fan you will see the oil filter coming out of front of engine
Mar 23, 2014 | 1990 Chevrolet Lumina
How to oil a standing Hunter fan
If the fan does not have 3-in-1 oil'r cap located near each end of fan, then lay fan down so blades are up. Then use WD40 with straw to spray on the turning shaft and let oil drip down for several hours.
You cannot over-oil a turning shaft, so plenty of WD40. Just be careful because air mist from WD40 is harmful to breathe and vapor is extremely flammable, so no smoking while spraying.
Sep 21, 2012 | Hunter (90121) Stand (Pedestal) Fan
AUTOMATIC SHUT DOWN WHEN THE UNIT IS HOT
hi,
First you have to check the lamp cooling fan of your projector. If the lamp cooling fan of your projector is faulty or it runs in a low speed this problem can occur. Another possibility is the faulty temperature sensor. you have to check the temperature sensor near the lamp. normally a sensor with two wire fitted on the lamp Cage.
if fan is suspected then remove the fan and try to oil the fan and the re fix it and try again. for oiling the fan watch the following video.
The video is for oiling a pc fan you can follow the same to oil the lamp cooling fan
ok
Jul 18, 2011 | Taxan U6-132 Projector
Where to oil the outside condenser fan?
Most modern condensing fan motors do not need oiling and in fact have no oil ports. If you have an older one then there is probably 2 yellow "****" on the bottom of the motor that you pull out and drop in a few drops of oil. You have to remove the top of your condenser unit where the fan motor is mounted to and turn it upside down to access the oil ports.
Jun 14, 2011 | Carrier 38CKC042 Air Conditioner
Samsung rm255lash, evaporator fan motor on refrigerator side making loud noise. We took off the panels as best we could but it seemed like it was frozen on. When I open the fridge and hold down the light...
i quick fix would be to take a quart of oil and remove the fan motor and soak it in the oil. This wont hurt it anter a couple of min in the oil, hang up so that all the oil can drain off it, then wipe it down. install motor and try again, let me know.
Feb 21, 2011 | Samsung RM255LASH Side by Side...
My fan is starting to squeel like it needs oil. Is there a p[lace to oil it? If so please tell me where to find the oil inlet. I have looked, haven't taken the fan down, just looked at it from a ladder.
Sorry to read about your problem, I hope this helps you out.
fans have sealed bearings, these types oiling wont work
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Hampton Bay 52 In. Cameron II Plus Ceiling...
Well its like i have an oil leak when im running on the freeway my oil pressure goes up and temp goes down but when i stop my oil pressure goes down and my temp goes up???...what could this be a valve...
Valve cover leak (oil) will not cause this problem, what needs to be checked is your radiator cooling fan, more then likely not working, that's why when your going down the freeway it don't over heat, you have air going through radiator, but when at stop, no air going through radiator to cool coolant before it goes back through engine, starts to get hot, and oil will also thin out, and have low oil pressure, check cooling fan's or fan, for voltage, should have voltage at normal oper. temp. about 210 - 220 deg., if you do have voltage and fan are not on, replace fan motor.
Sep 08, 2010 | 1986 Chrysler LeBaron
The fluid is pink instead of red for the cooling fan in my 2000 lincoln ls v8 I siphoned off the the tank and replaced with new fluid and it soon turned the same color
WHEN HYDRALIC FLUID BREAK DOWN WHILE IN USE CONTROLLING COOLING FAN.IT WILL TURN RED.THE ENGINE HEAT WHAT BREAK IT DOWN. LIKE ENGINE OIL. YOU PUT ENGINE OIL IN BROWN WHEN IT BREAK DOWN WHILE LUBRICATING ENGINE OIL BREAK DOWN IT WILL COME OUT DARK BROWN OR CLOSE TO A BLACK COLOR.
Jul 14, 2010 | 2000 Lincoln LS
92 accord: oil light blinking when car overheated
Ok this one is kind of hard to diagnose but maybe I can give you some answers. The 2 problems you have work hand in hand. If you have low oil level the heat in your cylinder walls raises because there is not enough oil to lubricate the fiction caused by the pistons going up and down. Secondly if your car overheats it gets so hot that the oil gets really thin thus viscosity break down occurs. Your Honda has an electric fan on the radiator and if this fan is not working your car will overheat. Crank your car with the hood up and let it idle till the temperature gauge comes up and the electric fan should come on. You will be able to hear and see this happen. If the temperature guage keeps climbing and the fan has not come on then turn your AC on and see if the fan comes on. They are tied together and when the AC is on the cooling fan switch is bypassed and runs all the time. You also have a oil pump in your engine that keeps the oil pressure moving inside the engine. If this is going out it will cause the oil light to come on and make your engine overheat. I am sure you have checked the oil level and the coolant level in your car but if you haven't please do that. I hope this helps you out to find your problem. Oh yea if the coolant fan comes on when the AC is turned on then you have a bad sensor and you need to replace that. In any case I would not drive it until you figure this out because it will for sure cause engine damage. Good luck, Roger
Feb 09, 2010 | 1998 Honda Accord
Can you help me
the fan only comes on when needed. the fan in my 92 would run alot in summer but i would never hear it any other time of the year. my jetta also had the oil light problem i was told it is the oil level indicator i drove the car for 6 years that way until i crashed it.
jattas are great
Oct 30, 2009 | Cars & Trucks
Hunter 22451 The Brookline Brushed Nickel Ceiling Fan Logo
20 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
