Question about Dishwashers
Asko 1555 Dishwasher will not drain. Bottom of kick panel pan will fill with water triping the float switch?, leaving an error code. Is it safe to assume that the out pump needs replacing. I had the kick panel off and smacked the motor housing a few times and it ran for a few loads, but is now again stopped working.
  • sydesigns Jun 26, 2008
    Asko dishwasher will not drain water in cycle. Please assist me.
It might be the pump, or it might be an obstruction elsewhere. If you have an air gap on your sink/counter top, open it and check for debris. If it is clear, unscrew the main filter basket. There is a black plug on the left side of the bottom well and you can pull it out after removing the filter basket. Feel around for any obstruction, and see if it is clear. Pull out anything that is blocking it, and make sure that you can spin the impeller freely with your fingers.
I had an impeller break on me. It costs about $30 for the part, and is easy to replace if you are handy. Just remember to unscrew by turning clockwise. If the motor itself is bad, it's about a $75 part and about the same amount of work as changing the impeller.
Posted on Oct 03, 2008
I have an asko d3251 dishwasher that won't stop running. The device in the drain that spins won't stop. I had to shut the power off to the unit.
Our unit had leaking connection on outlet side of fill solenoid valve. Any leak will cause water to accumulate in base pan. there is a float switch in base pan as a safety mechanism when water is in pan it causes a styrofoam float to rise and make contact with switch. This tells machine there is a leak creates error code to run pump continuously until water is removed from base. Disconnet electric from unit first. you must pull dishwasher out to get at back panel. Remove lower back panel to get access to mechanicals of unit. Once you remove panel you should see water in pan. If you see water that is most likely same issue we had. soak up excess water or tilt unit to drain water out of pan. once water is gone unit should start normally. If you look underneath while unit starts up - don't touch anything while unit is connected to electricity! You should notice where water is coming from. Our unit leaked at hose connection from outlet side of solenoid fill valve. connector is a plastic cam-lock fitting with a flow sensor integrated into it. there is an o-ring between the two parts. it comes apart with a very small amount of counter-clockwise motion. perhaps only five or ten degrees of indexing and it falls right off. it is a very flimsy connection for the main water line. the o-ring on our unit Was slightly deformed and not seated correctly. could have been from original installers 4 years earlier! Asko needs to re-design this part. I replaced o-ring and unit is working again however I do not trust that this fitting will hold up over time. Very poor design in my opinion. Other design flaw I noticed while looking at mechanicals is circulating pump isolation mount is not in correct location for pump motor. rubber mount is stressed to the point of almost tearing off! No way for me to correct this since location of mount does not match position of motor. We will not replace this unit with another ASKO when it goes.
Jan 19, 2013 | Asko D3251HDSS Stainless Steel Built-in...
Code F2
If you hear the drain pump running but water stays in the bottom then you have to check if the kitchen sink drain is clear. More particularly if you have a garbage disposal unit in kitchen sink then make sure it is working and has been cleared before running the dishwasher. In case you do not hear any drain pump or it is rough and not draining then it may need to be replaced. The drain pump is available from this site.
Jul 22, 2012 | Asko D1776 Stainless Steel Built-in...
Pump continually running with F2 displayed.
There is water in the lower pan that you must access by removing the toe kick plate and then the panel behind it. you will see water in the overflow area. Clean that out and all will be well. Asko's are awesome dishwashers that capture any water they may overflow or leak internally instead of it going on your floor, then a float switch triggers the F2 error and runs the drain pump.
May 30, 2012 | Asko D1716 Built-in Dishwasher
Getting an F4 fault code after about 1 -2 minutes of operation. There is actually water in the bottom of the unit. Have put a vacuum on the inlet feed tubing and also have blown compressed air through the...
Hello & Welcome to FixYa
F4 error in your Asko Dishwasher is a water fill fault and this indicates and over fill fault. To check and solve this problem please follow these steps:
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | Asko 24 in. D3350 Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
My asko dishwasher model 1595 flashers a f-2 code. I checked for a cloged drain. used my shop vac to empty the water in the drip pan then restarted the dishwasher.The pump came on and it continued to fill...
F2 High water level · Plugged/Bad water pump
· Defective water inlet valve
also check that the float switch is not stuck in the up position...
Hope it helps if NOT let me know more about your problem... and I will help
Aug 25, 2009 | Asko 1595 Dishwasher
Our Asko D3112 was not draining, so we had maintenance drain the hoses to clear any blockage but it did nothing. They said it must be our pump not working. I ran one more cycle to see if things went back...
Check your manual to see if you have a drain pan at the bottom of the unit, and a 'float' that checks for water collecting there. On at least some Asko models, water collecting in the pan causes the float to rise, which then changes the operation of the dishwasher. Once that float switch turns on, the diskwasher will always run the drain pump whenever power is applied.
If this is the case for your machine, remove the kick panel. There likely is another panel behind that which covers the 'internals', including the drain pan area. You'll have to remove all of the water in the pan, and that will lower the float and return the controller to normal operation. THen you will have to diagnose the cause of the water collecting in the pan.
Another possibility is damage to the float such that it has turned on it's switch despite no water collecting in the drain pan. I've heard that in some cases a mouse will chew on the float and damage it, causing such machine operation.
In another thread, I posted my solutions to one cause of water collecting in the drain pan. In that case the drain pump was no longer reliably moving water out of the sump area inside the dishwasher. I had thought it was the manual dial control on my d1706 unit, until I learned that the dishwasher has this 'special' drain pan mode.
Jul 07, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Asko 1805 Frozen
Sounds like the controlunit is bad.
Jan 01, 2008 | Asko 24 in. 1805 Built-in Dishwasher
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Dishwashers Logo
389 people viewed this question
Top Dishwashers Experts
