Question about Maytag MMV5100A Microwave Oven
Went to use microwave and it just went dead. Household power is fine and breakers are good. Replaced main fuse behind switch panel and got power back for clock etc.. When I went to run it again, it went dead immediately and blew the fuse I had just replaced. What else could it be?
    Habit-Forming:
  • 193 Answers
Short circuit in high tension power supply
DUE TO THE VERY HIGH AND DANGEROUS VOLTAGE 4000( V) IT IS NOT WISE TO FIX IT YOUR SELF UNLESS YOU KNOW WHAT YOU ARE DOING
Posted on Apr 27, 2010
GE JES1344SK01 countertop microwave, no power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall, in which case you can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams by entering your full model number here. Once you have the part numbers, though, I would suggest ordering parts here at a much lower cost.
Dec 16, 2008 | GE JES1344SK Microwave Oven
My GE Built-in microwave model JVM1870 appears to have died
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download GE owner's manuals and installation instructions here to make that easier.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 16, 2008 | GE JVM1870 Microwave Oven
My GE advantium microwave oven 220 out of no where just quit working , no power to it all, digital light for time ect just went dead while rewarming up a bag of steam green beans. Theres wasnt a ...
You can download GE owner's manuals and installation instructions here.
If you'd want to scan and e-mail or copy and fax the mini-manual (or at least the "schematic diagram page) to me, I'd be happy to make more precise suggestions.
Nov 29, 2008 | Microwave Ovens
Control panel went off and hence it stopped working
You can download Frigidaire / Whirlpool installation instructions here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 26, 2008 | Frigidaire PLMV169DC Microwave Oven
No power
Then you can get to the door switches to check them.
Also see
http://www.microwavedisplay.com/doorsw.txt
Nov 25, 2008 | KitchenAid KHMS155L Microwave Oven
Microwave went dead
You should also check the high voltage rectifier diode to be sure it's not shorted too: http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
You can find an authorized Panasonic servicer here. You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Nov 02, 2008 | Panasonic Microwave Ovens
It just died
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
Sep 21, 2008 | Whirlpool MH7155XM Microwave Oven
No Power
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
Aug 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Samsumg CE283GLT does not power on
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
You can order Samsung parts here. To find an authorized Samsung servicer, see this page.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 20, 2008 | Samsung Microwave Ovens
Replacing the fuse of a MCO160UW
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Jul 15, 2008 | Magic Chef CMV1000B Microwave Oven
Maytag MMV5100A Microwave Oven Logo
216 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
