Question about Dell Inspiron 1525 Notebook
Wlan card failure
Dialog box states "wlan card failure"
  • Dell Master
  • 1,183 Answers
If you are getting the above error message , the same could because of two reasons .1. the wireless card is loose 2. the wireless card has gone bad.
Try re-seating the wireless card and then check. Steps on how to do the same are given below
http://support.dell.com/support/edocs/systems/ins1525/en/SM/minicard.htm#wp1181360
Thanks for using Fixya
Proton
Posted on Apr 26, 2010
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
Were is the wireless turn on switch?
It appears that there isn't an external switch to turn the WLAN off on the Everex NC1500 laptop (click here for the full manual). Here is a link showing you how to disable and enable WLAN card in WinXP (click here) if this is what you are trying to accomplish.
According to the manual (if your wireless isn't working) you must first install the WLAN driver before using the wireless connection. Info: "Wireless LAN module is similar to LAN module. You need to install software driver before using it. Please refer to Appendix B on how to install the driver." Appendix B INSTALLING THE WIRELESS LANDEVICE DRIVER Please follow the procedures below for installing the Mini PCI Adapter driver: Installing Wireless LAN driver for Windows XP 1. Click the Start button and then click Run. The Run dialog box appears. 2. Click Browse button and specify the directory as "E:\Drivers\Winxp\Wireless LAN\setup.exe" 3. Click "OK" to implement the setup program to install this driver. 4. Click "Next" twice to continue the installation.
Hope this was helpful.
Feb 01, 2011 | Everex StepNote NC1500 Notebook
Toshiba satellite L500-1R0, fn hotkey is not functioning to on the wireless of the system. please help with the software i can download to to use it on my system wireless on.
Hi, have you tried the front wlan switch? It is located at the front of your laptop and usually will resolve the problem. If it is already on, then turn your switch off and then on. Also double check the function key to make sure that it is on. If it still doesnt work, you will need to start checking other things such as drivers, and if the drivers are there, then it could be a wlan card failure. To check the drivers, click on Start>>right-click on Computer>>left-click on Manage. On the left, click on Device Manager, and under the heading of Network Adaptors, see if there is anything corresponding to your wlan adaptor. If there is nothing like this, then your card seems to have failed. Otherwise, a yellow exclamation mark indicates a driver problem. In this case of a driver problem, right click on it, and then click on uninstall. Restart your computer and see if the wlan works. Failing all of that, it would point to a wlan card failure. Hope this information helps
Nov 06, 2010 | Computers & Internet
How do I turn on my wireless
HERE IS THE RESOLUTION
To turn the WLAN wireless card on and off, use the FN + F2 keys. The F2 key has an icon on it that looks like a large radio transmitter tower. Pressing the FN+F2 keys again will reverse the state of the WLAN card. There is a green LED (with the same transmission tower picture) at the right edge of the keyboard that will illuminate when the WLAN card is on. This WLAN status LED is located to the right of the "Home, End" key.
Sep 18, 2010 | Systemax Computers & Internet
My mc3070 motorola scanner won't connect to the internet, or scan any tickets.
MC3070 is equiped with 802.11b/g radio so the WLAN connection should, do you see any WLANs available in the Find WLans dialog?
The Find Wlans dialog can you open through an icon of the Fusion application in the right corner.
For scanning would you need an software, usually is a demo software preinstalled. You could find it in the Application Folder. The demo software is called ScanSample or ScanWedge.
You can also download an application called DataWedge from the support.symbol.com website
Sep 04, 2010 | Zebra Symbol Technologies MC909X-G Series...
The Update Assistant keeps opening a dialog box stating that it has no access to the router. But whenever I try to do anything in the dialog box--click a button or close the dialog--an Internet Explorer...
1.Press Windows logo key + R, type winver and hit Enter key.( Check the version details of Windows 10 installed on your computer).
2.Shutdown your device ,restart it back and then initiate the upgrade to see if goes correctly this time.
If any third party Antivirus or Online security software is installed, then try to disable it for a moment then try to initiate the upgrade to see if it goes correctly.
In case problem still persist, then try to upgrade it in Clean Boot state.
1. Press Windows Key, type msconfig in the search box, and hit Enter.
2. On the Services tab of the System Configuration dialog box, tap or click to select the Hide all Microsoft services check box, and then tap or click Disable all.
3. On the Startup tab of the System Configuration dialog box, tap or click Open Task Manager.
4. On the Startup tab in Task Manager, for each startup item, select the item and then click Disable.
5. Close Task Manager.
6. On the Startup tab of the System Configuration dialog box, tap or click OK, and then restart the computer.
Apr 08, 2017 | NetGear WNDR3300 - RangeMax Dual Band...
Wireless button showing amber, but wont change when pressed
WIRELESS NETWORK BUTTON FIX FROM RED TO BLUE. 1. Press wireless button. 2. left click the dialog box in the bottom right corner it will prob say wireless disabled etc. 3. HP wireless assist box should open if so its working and you should click on properties. 4. check all unchecked boxes and press apply or ok etc.5 you should now see in the top right corner of the HP wireless assist box an option to turn on wifi press it. 6. Try the wifi button it should work! If not sorry it did for me.
Apr 15, 2010 | Compaq Presario CQ60-220US PC Laptop
I just had this ASUS WLAN card Bus Adaptor IEEE 802.11g and I installed it the way it was written in the manual. First I installed the CD. after which I restarted my computer as required. Now, I tried to...
This errro comes becasue of 2 possibility
(1) virus all malware infection.
(2Newdev.dll is not installed or corrupt.
For that you need to scan your computer with antivirus and antimale ware with updated.
Then enter in safe mode.
When you power up the computer pressF8 key then enter in safe mode.
then uninstall your wlan drivers fom there then restart in normal mode then install again drivers.It fix issue.
If still face errror then replace
Newdev.dll from original source.
Thanks for using fixya.
Please rate solution if it helps you.
Jul 18, 2009 | Computers & Internet
Keyboard types wrong letter
  1. Click Start, and then click Control Panel.
  2. Under Pick a category, click Date, Time, Language, and Regional Options.
  3. Under or pick a Control Panel icon, click Regional and Language Options.
    The Regional and Language Options dialog box appears.
  4. On the Languages tab, click Details.
    The Text Services and Input Languages dialog box appears.
  5. Under Installed services, click Add.
    The Add Input language dialog box appears.
  6. In the Input language list, click the language that you want. For example, English (United States).
    NOTE: When you use the United States-International keyboard layout, you should also use an English language setting.
  7. In the Keyboard layout/IME list, click United States-International, and then click OK.
  8. In the Select one of the installed input languages to use when you start your computer list, click Language name - United States-International (where Language name is the language that you selected in step 6), and then click OK.
  9. In the Regional and Language Options dialog box, click OK.
    Notice that the Language bar appears on the taskbar. When you position the mouse pointer over it, a ToolTip appears that describes the active keyboard layout. For example, United States-International.
  10. Click the Language bar, and then click United States-International on the shortcut menu that appears.
Thanks,
Armymason
Mar 02, 2009 | Dell Dimension 4600 PC Desktop
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
Dell Inspiron 1525 Notebook Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
