Question about Planar PT1814NUV 18.1 in. Flat Panel LCD Monitor
I have a Planar PT1814NUV monitor that powers up, but displays wide (about 1") vertical bands. They are white & magenta, alternating like prison garb (only vertical) superimposed over the monitor controls window. Any idea what's wrong with it and if/how it can be repaired? Thanks!
  • jyjazz May 04, 2010
    Thanks for responding!
    Does this mean the whole panel or just components like the fuse(s)? If the entire panel, is it even worth it?
    Thanks for your help!
  • 11,361 Answers
This the symptom of failing T-CON board which is part of the LCD panel assembly, the LCD panel will have to be replaced.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
It will get worst with more lines/bands.
Posted on Apr 29, 2010
Testimonial: "Quick responses!"
  • Bud Martin
    Bud Martin May 04, 2010
    Not worth it, the whole LCD will have to be replaced.
  • 732 Answers
Jyjazz, If all connections have been checked and are still good (not loose) then check the units "date of manufacture" on rear of unit!!! It could be that it is 6 to 8 years old and has had a long life compared to all other brands that never made it past 4 to 5 years of age. Yes, you will need to make decision based on good approximation of the total "on" hours this unit has seen during it's lifetime and the last known GOOD screen images that were displayed. Do a little bit of reading of my fixya profile and those of "budmrtn" and "buddymc" for more info on getting monitor repaired or trading in for new. Bye for now. 12fixlouie
Posted on Apr 26, 2010
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Monitor displays wide vertical stripes/bands
That is the symptom of failed T-CON board (part of the LCD panel assembly, new panel will be needed), you can try reseating the ribbon connector on the LCD panel first.
This what T-CON board looks like:
Posted on Apr 27, 2010
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
Apr 26, 2010 | Planar PT1814NUV 18.1 in. Flat Panel LCD...
I have a 2inch wide band down middle of screen on
1) Have you installed new drivers or software or drivers? If so, remove them and restart the computer.
2) Try applying pressure with your fingers on top of the screen. If the band dissapears or dimishes, you may have a broken screen and it will need to be replaced.
Mar 19, 2010 | HP Pavilion zd8000 Notebook
Vertical white wide band - Shivering fonts
Unfortunately that sound like a defective LCD panel. You can verify this by plugging the system into an external monitor. As long as the shimmering band does not appear on external display then it is the LCD. If it is under warranty I would suggest taking it into Apple.
Aug 16, 2009 | Apple MacBook Air Mac Notebook
Continuous vertical white band display problem
What is the error from installing xp sp3?
Is the white band always there? it is either a problem with the lcd panel most likely, or the graphics card. try a different monitor if you have one.
Jun 21, 2009 | Dell Dimension 9100 PC Desktop
White 1 inch vertical band on display
just a thought.. Either your Graphics card or your Video Card has gone bad.. unfortunately DELL has a tendency of putting the graphics ON-BOARD and IF the onboard grqaphics card is bad, you'll need to get into the BIOS and turn the onboard graphics off then purchase an after market Graphics driver.. IMPORTANT: make certain that the graphic cars is compatable with the DELL PC OR purchase a less Proprietary system
May 04, 2009 | Dell Dimension 9100 PC Desktop
White Vertical Band on Screen
Hi...there,
It's seems you got a busted screen panel...
Dec 15, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
KDS K717s 17" LCD Monitor
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Feb 21, 2008 | KDS K717s 17" LCD Monitor
Wide vertical black and white bands
Hi, You may want to try and unplugging the power and video connectors of the Dell monitor. Check for anything out of the ordinary with the AC plug and the video connector. If none, plug them back in making sure that they are snug and fitted properly. If problem persist, see if it is possible to rotate the way the AC plug is connected to the mains (sometimes this works and can be done if you are not using 3-prong or the uneven 2-prong AC plug. Sometimes, this can also be done on the other end of the AC plug). Check your docking station (though unlikely but possibly). If still a no go and your laptop works ok, then your external monitor needs some looking at. This would involve circuit analysis and component level repair. Perhaps your best bet is to have a qualified professional take a look at it. Good luck and pls post back how things turn up or if you need further information. Kind regards.
Aug 20, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Planar PT1814NUV 18.1 in. Flat Panel LCD Monitor Logo
102 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Joe Goldman
Joe Goldman
Jay Plesset
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
