Question about Panasonic PT-51HX41 51" Rear Projection Television
Stk392-110 chip replacement
Hey TVtech guy
I have surfed the web and found an array of info on replacing the stk392-110 chips with the 150/180 series. I have a JVC AV-48WP74 - existing chips are the 110 series. What is the best choice for replacing chips - 110 or maybe the 150/180. Thank you for your input.
timetosolder
Stk392-110/150/180 all have same fit, form function except the 150's and 180's are basically upgrades for they're more stable (more heat tolerant than the original 110's); I'd buy the 150/180 myself; you can get the stk392-180 for just under 10 bucks on eletronix.com.
Posted on Apr 20, 2008
  • Panasonic Master
  • 3,459 Answers
In general its never a good idea to replace *** chips for YYY unless you are 100% certain they are compatible. We help thousands of people do convergence repairs each year and in some cases they come to us after using the wrong chips.And as others have pointed out above using the wrong ones can and will burn up the convergence resistors. Overall its best not to take any chances and just replace the chips with the original OEM versions. This is why we have complete kits at www.TvRepairKits.com - to eliminate the guesswork and insure the correct parts are used.
stk392-110 chip replacement - 5_21_2012_3_45_10_am.pngSOLUTION
Posted on May 21, 2012
I have a blue sadow on the image of the tv
Posted on Apr 02, 2008
    Novelist:
  • 132 Answers
The 110 , 120, 150 ICs are all different. If you insert the 150 in for a 110 the result may well be burnt low ohm resistors.
Hitachi suggested replacement of different STK's for originals, but always provides different low ohm resistor values for the modification.
Hitachi uses 110 and 150 for H and V convergence in 51F500. They are different.
Use only the original IC or the kit with replacement resistors as advised by the manufacturer. Or if you insist on using the 150 in a JVC, at least re-design the circuit first, then you won't email again asking why it doesn't work.
easyab
Posted on Aug 20, 2008
What is part number zilog3055 on circuit board of DW9107 battery charger?
this 3055 ?
The zilog3055 device is a fully integrated, single-chip, pack-based solution that provides a rich array of features for gas gauging, protection, and authentication for 2-series, 3-series, and 4-series cell Li-Ion and Li-Polymer battery packs.
Using its integrated high-performance analog peripherals, the bq3055 device measures and maintains an accurate record of available capacity, voltage,
Nov 04, 2015 | Drills
Gateway ZX4300 Black Screen troubleshooting
Follow this guy's responce on youtube. Worked exactly for me.
http://youtu.be/9psRUnJnR3o
Jun 30, 2012 | Computers & Internet
Blue outline of picture
Try to adjust the digital array, if it is still bad the two chips will need replacing. I've had it done three time in 7 years at $300.00 a pop
Feb 28, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
I need to replace the chip 478b, because to pins are broken off. I want the same or a compatable one for my motherboard P4 X 400DBP. Where to get/buy the chip would be a good start. Intel P4 processer...
Hey man, found you one cheap at the following link. Don't forget your thermal paste, very important.
http://www.weirdstuff.com/cgi-bin/item/13363
Jun 20, 2009 | Computers & Internet
Not responding system of my hp compaaq nx6120 when..
Just change the BGA chip (FW82801FBM),genrely known as south brige.
Mar 03, 2009 | HP Compaq nx6115 Notebook
Use the STK180s they are the best the 110s do not hold up the leggs fall off after connducting to much heat.These ICs must be solder in see if you can find someone who can solder to remove old ICs and reinstall new ones you will also need white silicon heat sink to put on back of ICs as well.
Feb 13, 2009 | Toshiba TN55X81 55" Rear Projection...
Thank you very much. So sad hic hic. I'm going to try fixing it myself. I tried to find document saying about mainboard circuit but I found nothing. Do you have any suggestion? Best regards,
You won't find anything on the circuitry, not even from Dell. I was chatting with a tech Friend the other day on the same issue for a Dell machine. He had traced the chip down on the board and asked if I had one or could find one. After looking through all my resources and talking to a Dell tech that I use, found nothing. The Dell tech that I use couldn't find anything on the specific chip with his Dell resources and told me that motherboard replacement was the only option. Which I already knew. I've tried replacing the chip before with chips from dead parts boards that I have, and have only had about a 15% success rate. The chip replacement is a real nightmare, involves soldiering on the board under the chip. So, I'm sorry, but there's no info on this. I may be able to get you break down diagrams and instructions for your machine if you want to replace the board yourself. Let me know.
Jul 27, 2008 | Dell (F2273) Motherboard
Drum replacement message dell 3100cn
I have found no way to do this, the only option is to replace it, there is no reset like the Dell 1700 series.
Mar 12, 2008 | Dell 3100cn Laser Printer
Replaced IC chips and fried something
1)WHICH chips?? 2)Which resistors? (locations) 3)It is worth it. 4)Possible,but usually not needed.
Sep 19, 2007 | Panasonic PT-53WX54 53" Rear Projection...
No sound or pic
Their is an IC that went out. You can get a replacement chip and repair instructions from www.magnavoxhelp.com
Nov 28, 2006 | Philips 9P5534C 55" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
1,614 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
