Question about Brother MFC 420CN All-In-One InkJet Printer
Paper jam paper gets jammed in machine constantly, we are a restaurant who prints multiple copies at a time. Machine will say either paper not fed or it gets jammed in machine, front, back, etc..
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Paper jam
  • Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  • 2Turn off the copy machine before pulling out the paper.
  • 3Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  • 4Check for any paper fragments and clean up any torn pieces.
  • 5Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  • 6Replace the cover and paper tray and turn the machine back on.
  • 7Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push
    see the diagram for copiers and let`s the way of paper for troubleshooting .
  • 12_19_2011_4_33_16_pm.jpgsincerely. Merry Christmas.
    ernesto cuadra
    managua, nicaragua. c.a
    Dec 19, 2011 | Office Equipment & Supplies
    Tip
    How to Fix a Paper Jam in a Copy Machine
    It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
    1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
    2. Step 2 Turn off the copy machine before pulling out the paper.
    3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
    4. Step 4 Check for any paper fragments and clean up any torn pieces.
    5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
    6. Step 6 Replace the cover and paper tray and turn the machine back on.
    7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
    on Jul 14, 2010 | Office Equipment & Supplies
    Had paper jammed - removed jammed paper - but nerror light still on
    Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
    First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
    Paper is jammed inside the paper tray:
    1. Pull the paper tray out of the machine.
    1. Pull out the jammed paper to remove it.
    1. Reload the paper in the paper tray.
    2. Reinstall the paper tray.
    Paper is jammed inside the machine:
    1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
    1. Re-insert the jam clear cover.
    2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
    3. Remove the jammed paper.
    4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
    5. Gently move the print head to the center.
      Note Be careful to not force the print head to move.
      If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
    6. Examine under the print head. If anything is found, remove it.
      Note Use a flashlight if necessary to check thoroughly.
    7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
    8. Reconnect the power cord and telephone line.
    Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
    If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
    Thanks for using fixya......
    Oct 26, 2010 | Brother Office Equipment & Supplies
    My MX-2300N Printer/Copier/Scanner is having a copying error. The main screen constantly says "Remove paper from center tray, yet there appears to be no paper in the ccenter" tray. I have reset the machine...
    Please verify that no printer paper is jammed or partially fed into the printer. If you have one or more pieces of paper stuck in the printer these will need to be manually removed before the printer will print again.
    Aug 06, 2010 | Office Equipment & Supplies
    I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
    I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
    Jan 11, 2010 | Canon imageRUNNER 2200
    Won't photocopy / warning light flashing /
    The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
    Jul 16, 2009 | Canon PC170 Copier
    Paper jam
    Call HP and replace unit under warranty.
    Jun 20, 2009 | HP Officejet Pro L7680 All-In-One Printer
    Ricoh copy machine 3025 paper jams every time we try to print
    Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
    Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
    Paper Jam
    Some basic non-tech questions:
    • Are you using paper that's been allowed to sit open for weeks? It might have absorbed water.
    • Are you in the habit of reusing paper that's double-fed? I used to, but it's more likely to jam
    • When was the last time the technician was in to do a preventive maintenance? The machine may need a basic clean-and-check.
    • Check your manual, and check what the machine is telling you (on the display, if it has one). The location of the jam may give you an idea of the reason for the jam (jamming at the fuser may indicate a cold fuser, jamming at the drum can be caused by broken separation fingers, etc.) If you have a technician, this will be useful information.
    Nov 22, 2008 | Toshiba 2060 Copier
    PAPER JAMS
    Does the fault clear when you open/close? If it does you probably don't have a jam.
    Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
    Nov 11, 2007 | Office Equipment & Supplies
    Brother MFC 420CN All-In-One InkJet Printer Logo
    52 people viewed this question
    CheckitRight
    CheckitRight
    Ron Dufek
    Ron Dufek
    James Cagle
    James Cagle
